hey guys
i need some help.. i want to get screamer pipes on my r32 gtr....
would i have to get them made up or is there some place where you can buy them that would fit??
if so how much do they usualy cost?
advice pleaseee!!
Edited by khamb
i dunno about a gtr screamer but an rb25det screamer is $100 from just jap.....
why cant you get a pair of these for $400, get an angle grinder and a welder and make your own screamer for $400 for a set for both turbos on your gtr???? it'll probably take you a good hour to make it up, just plan how your going to do it before you start cutting lol
http://justjap.com/store/product.php?produ...=276&page=1
So you have a big single, with external wastegate and so on?
Otherwise, with stock turbos, or internal gate turbos, its a waste and all the hot air is going to do is mince the rubber hosing
I'd say he just wants the "WAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH" when you floor it
my motor is being rebuilt as we speak. Forged pistons forged rods. Sump baffle garret 2860 turbos powerfc and much more. So the turbos just a little bit bigger.
And I want it to sound tuff when I get back. Im putting 13 grand into it. So I wouldn't want anything to wreck it I guess.
Dumb question what's an external gate and where isit located
I've only still got a stock cooler! If that helps LOL
And your exactly right LOL I do want to hear the sound of waaaaaaaaahhhhh when I floor it
Good stuff mate!
waste of time with your small twins. they have internal wastegates. internal wastegate turbos are not designed to have seperate pipes from the wastegate and the turbine outlet. you can tell this as there is just one outlet and one flange for both. on an external wastegate set-up you have a seperate wastegate and it has it's own outlet. most often people will merge the wastegate oulet pipe with the turbine outlet pipe somewhere along the exhaust. some however leave the wastegate pipe to vent to atmosphere (a screamer pipe).
it is possible you could get some kind of frankenstein set-up to try and vent your internal wastegates to atmosphere but it won't have good result. you will have a constant exhaust leak and your car will sound like some kind of tractor most of the time. all the exhaust in your engine bay will possible melt stuff and discolour everything. and it wont sound that great either when the wastegates open. seriously, don't bother. you want a screamer then you need a turbo that does not have an integrated wastegate. also, they are highly illegal in every state of australia and if you are caught with one you could find yourself with a serious problem.
I am running hacked up HKS dumps on my twin rr581 low mounts. As long as they have welded in a seperate plate between the turbo wheel outlet and the wastegate inside the dumps it will sound fine at idle, its when ppl don't do this that it will sound bad.
I didn't really do myn for sound, I was actually looking for just a good set of HKS dumps without the screamer, just happend to get these off JPS for a damn good price second hand. They sound sweet but, just like any other screamer I have heard, and they are a definately an improvement as far as exhaust restriction is concerned.
Try hit up importmonster and they like, they are readily available through yahoo japan second hand.
Edited by James_03
so you guys are saying I shouldn't get it going to atmosphere. Would those dump pipes in the link above be suitable. And would dump pipes sound anything close to a screamer.
I wouldn't want it have a leak at all. But I've seen before on r32 gtr with the same turbos and it was screaming at the same time but I don't know his setup and there was no leaking sound and at the same time was sounding very good at idle. Couldve been dump pipes though!
Sounded bloody tuff though!
there is no way you could get a perfect seal between the wastegate and exhaust sides of the housing. and as more exhaust gasses pass through the dump pressure increases and the leak becomes more noticeable. hence why they dont sound the same as proper gate there isnt the same "snap open, snap close" of the gate due to the leak.
put some of your 13grand twoards getting turbos without internal gates and then set yourself up with sopme external gates and screamers if you want to do it properly
Well there you go, proved wrong again by the people that have never done it.
Say no more.
well james 03
do u have interanally gated turbos?
if so does your setup work.
also will dump pipes give and screaming??? at all. or is a waste of my time guys????????????????????
sorry mate where could i get those from...
do they sounds good though..
what is the ruff price on those shown in images
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
