Group Buy: Skyline Power Steering Cap Cover Plates
Hi all,
Over the last year and a half I have been engaged in the rebuild of my R34. During this time we have spent a lot of time and effort adding small touches here and there to make things a bit more unique. Some are specific, and others are more generic (i.e. for everyone)
One such part that we came up with was a cover plate for the R34GTT Power Steering Cap. Even though the standard one was in OK shape, I found that it was a "dull" point when compared to the rest of my engine bay which is mostly filled with shiny bits n pieces. So as per usual, the spanners were dropped and the drawing board was manned. The design brief was "simple, easy to fit, and attractive". Once the design was finalized, Ann Harris @ K-Bar was contacted to do the hard work - as always she delivered with fabulous results.
Business Details:
Ann Harris
K-Bar Laser Etching
http://k-bar.com.au/
All our initial designs involving this technology were sent to numerous suppliers around Australia. Ann came back with the lowest quote from everyone, and was happy to assist with material choice, artwork and other recommendations. In total, around 20 suppliers were contacted and these guys were by far the best deal for our purposes (i.e. once off designs and productions)
What's on Offer
For those who took part in the R34 Fuse Box Plate Group Buy, the quality of the item is already known... the photos below show MY OWN version of the Power Steering Cap Plate - the final picture is the artwork that Ann has done for me, so I can offer it to you guys. Please note, even though I am 99% sure that this is good for ALL Skylines (dimension wise), please check by taking a ruler to your engine bay!
The third picture is the artwork sent to me this morning by Ann - there are a couple of designs there to choose from. I am under the impression that the numbers required for this GB are TOTAL UNITS, not UNITS PER DESIGN. So mixing n matching the order is fine.
imgp3285al3.th.jpgthpix.gif imgp3287jo4.th.jpgthpix.gif fromanngt3.th.jpgthpix.gif
Pricing
Ann is still finalizing the quote based on 0-10, 10-20, and 20+ units.
Just like the last group buy, pricing will include 1x Plate, Postage, and maybe a little surprise (not guaranteed)
GROUP BUY END DATE AT THIS STAGE IS: 15/11/2008 (or earlier pending public interest)
Specifics
Material: 3mm Metalgraph Plus (brushed stainless look)
Etching: All etching will be in BLACK (no exceptions)
Holes: No mounting holes will be needed; two small dabs of adhesive are all that is required for mounting
Care: Minimal care is required, this material is scratch proof - an odd wipe wouldn't hurt though
Interested pending price. Won't want to pay much for such a little thing :dry:
Is one of the bottom 'GT-4's supposed to read 'GT-T'? I would prefer that.
OK quote has just come in from Ann...
10 $18.00 each
11 – 20 $17.00 each
21 – 50 $16.00 each
51 + $15.00 each
Please note that the above pricing includes everything (choice of design, and freight). From time of order being placed to delivery, expect 4 days (going off last Group Buy)
  • 1 month later...
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
