Item: RB30DET - RB25 VVT Head
Age: <300KM old
Condition: Excellent, Very little use
Price: $5000 ONO (Open to Offers for a quick sale)
To Fit: (What car) VL or Skyline
Contact:
Comments:
Engine was built for our last Race car but since then have a GTR landed. Engine was run in, Made 306RWKW on 18PSI with a Power FC, 700x300x120 Intercooler & 3.5” Exhaust & bosch 040. Engine was purposely built with lower compression ratio to run some serious boost.
Head
RB25 Head, mild match porting, RB25DE Cams with RB25DET Valve springs, Rear external Oil Drain, VVT Disabled internally, RB26DETT Rocker Covers powder-coated Red (cost $450 by the time they were coated), head was professionally welded & resurfaced.
Block
RB30E Block, was freshly rebuilt to STD spec, Brand new idler & Tensioner, Gates RB30DET Racing timing belt, RB25DET Oil pump, Sump modified for external oil drain returns (on either side), Currently Has R33 Engine Mounts
Mods: (everything was brought brand new within the last 6 months unless specified & barely used)
Some of our rough costs
$400 -Front facing Plenum, Greddy Style, but had over 10 Hours match porting & Cleaning up.
$200 -80MM throttle Body
$820 -Sard 850CC injectors
$2500 -Trust Greddy TD06-20G Turbo, manifold & wastegate (2nd hand – but in excellent condition)
$320 -Z32 AFM
$550 -Splitfire Coil Packs
+ there will be stuff I have missed.
Comes with loom but no ECU (loome suits front facing plenum & Z32 AFM)
In reality the engine owes us over $8,000 to have built up & tuned, as you can see just in Mods there is over $4,000.00
Urgent Sale, need to make final payment on GTR.
Looking for a quick sale $5000 or nearest offer.
Engine does not come with Power FC – as it has already been sold.
Cheers
Have some video & pics to follow
Yeah also have an OS Giken tripple plate clutch with heaps & heaps of meat left on it - $1000 ONO
R33 Rolling Shell with a full 6 point welded cage, R34 Rear end (with mechanical diff), ohline rear coil-overs, tein front, 3.5" exhaust, Jun front bar & side skirts, URAS rear bar, front Adjustable caster & camber arms, all brakes, etc
Racecar only (complete minus headlights basically(except no interrior) has manual pedal box, etc
(cage is built to CAMS spec, but has not got approval yet). Front gaurds have been flared, body is in canary Yellow
$3000 ONO (cage cost $2500 to have fabricated)
Also R33 GTST gearbox, in good condition $1500 ONO
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=120318536610
Listing it Guys, 5-day Auction....
If anyone is interested contact us ASAP and it will be taken down
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=120318824694
EBAY CANNED THE LISTING 3 TIMES BECAUSE OF:
MENTIONED IT WAS ADVERTISED ELSEWHERE
MENTIONED OPEN TO OFFERS
MENTIONED THE SHELL FOR SALE IN THE LISTING
BASTARDS! CHARGED ME EVERYTIME!!!
Willing to send overseas Dock - Dock, buyer to organise freight from the dock in their country & customs etc...
With our dollar where it is at the moment, cheap time for anyone to buy from overseas!!
Have a few people internationally interested..
Cheers
hey, im interested in the head and block assembled, not needing any boltons at all, if your willing to separate let me know a price iand i will take it.
cheers, let me know.
very interested
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
