I'm looking at the yahoo.co.jp auctions and a toshiba screen goes for about 40k yen ($400 usd)
eg http://page6.auctions.yahoo.co.jp/jp/auction/f72604289
(to replace one in the MFD with broken pixels or whatever)
but I found this
http://store.earthlcd.com/SK-3021-SK3021
for $92 USD which is the same model screen, with some basic frame and power attached.
So I'm wondering if I can't just buy the $92 unit and extract the screen, then I'll have my MFD
replacement ? The PDF from toshiba makes it look identical:
http://www.earthcomputer.com/public_html/d.../TFD58W30MM.pdf
whatcha think?
Good find I've been trying to find an equivalent for a while, I think for the cost difference it's worth getting one to try there won't be much to it from a technical standpoint...if anything but plug n play
Give Chris Rogers a PM and get his opinion.
Well, for $92 usd, I figured it was worth a try so I ordered one and when I get it, I'll rip off the
added circuitry and find out very quickly if it does the job or not.
Stands to reason they should be cheap. I imagine in 2000 they were hot stuff but now they're
almost disposable at that resolution.
  • 1 year later...
Did this ever work? I am looking for a sharp replacement for my Sharp MFD screen, model Sharp 6L-U7WJ
The toshiba panel works, if it replaces a toshiba panel.
A buyer with a Sharp panel bought one and said he thought he could adapt it. I can't remember who he was, I'll look in my email box. Perhaps he achieved his goal.
Anyway I still have some left, if anyone has a toshiba with vertical lines or dead, in an MFD.
email me, almostfreecoogee .. gmail.com
Edited by moneypit
  • 4 weeks later...
  • 7 months later...
Looks like the GTR's after 00 have the Toshiba screens and the 99 models have the Sharp screens, from what google tells me.
Cheers for that. I'll do a bit more research and see if I can confirm.
  • 2 years later...
I have a working Sharp unit in my '99 V-Spec N1 Chris.
I've been given the upgraded Nismo unit which adapts it seems, to the Toshiba wiring.
I'm in a conundrum here.
You're not resolving the same issue are you?
Not quite. I have a full sharp mfd unit in my possession. I am going to yank the video portion off the sharp screen and adapt it to another screen.
Still working out how the video generation is done at this point in time.
Looks like the screen board does the video conversion and that is dropped to a second board on the LCD panel itself.
I will have the scop out tomorrow and start deriving signals. It looks like the sharp LCD panel takes raw video and 'RGBS' and processes it at the LCD panel.
Will know more tomorrow.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
