You might have a problem. Usually mixture related, possibly a faulty AFM, or bad tune on an aftermarket ECU. Going off the fuel gauge isn't very accurate though, fill it up and work out your L/100km.
Anything higher than 15 or 16L/100km around town usually indicates a problem. But even if it's fine, you can usually tune it and get it down to around 14 or less. Low 13's is pretty good, anything less is a bonus. On the highway you should be getting around 10 or 11 tops.
My r33 GTS4 (non turbo) has horrible fuel economy.. sure i do drive with the foot down a fair bit but even then i get around 16L/100KM.. i havent had it actually "tuned" since ive had it (1year) but i thought the ECU does that itself?
my car is fully stock, probably only spend about 20% of driving time with the bost gauge in the positive boost area.
so it would be a good idea to get some new plugs and clean the AFM?
if this doesn't work does anyone know of a good tuner arounf the liverpool area?
related threads on this topic are rampant throughout this forum, do a search and see what other people are saying....this only indicates you're not the only one who thinks they have fuel problems/issues - so is it really an issue or is it just paranoya???
imho, in sydney, because of the traffic and petrol quality i would be extremely surprised for a stock rb25 to average better than 350-380km a tank. i've noticed people from victoria with extremely good fuel consumption figures, but they dont have the traffic of sydney, they probably have better fuel & it depends on the type of driving they do...highway vs city
i have a powerfc tuned to about 12:1 AFR and i will consistently hit 400km with a mix of city/highway/full throttle. before the tune i would be lucky to get 380km per tank.
unfortunately, you can't tune your ECU as its stock. you will have to get an aftermarket fuel controller (apexi safc) or replacement ecu to do this.
how many km's has the car done? if its not time ie. 50,000 or 100,000km's you might try as everyone says, re-gapping your spark plugs, replacing your airfilter element, cleaning your AFM & replacing the fuel filter.
...but otherwise, live with it! its a 6 cylinder turbo. its a performance car. performance requires fuel. having said all this, you're still doing better, from a fuel consumption perspective, than a V8 or Rotary! :D
Hey franks, i was not complaining, just surprised, in my old 180sx (2ltr with 14psi exhaust etc) i used to drive with the throttle fully imbedded into the carpet most of the time and it still returned better figures than my skyline and this surprised me, that is all
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
