You might have a problem. Usually mixture related, possibly a faulty AFM, or bad tune on an aftermarket ECU. Going off the fuel gauge isn't very accurate though, fill it up and work out your L/100km.
Anything higher than 15 or 16L/100km around town usually indicates a problem. But even if it's fine, you can usually tune it and get it down to around 14 or less. Low 13's is pretty good, anything less is a bonus. On the highway you should be getting around 10 or 11 tops.
My r33 GTS4 (non turbo) has horrible fuel economy.. sure i do drive with the foot down a fair bit but even then i get around 16L/100KM.. i havent had it actually "tuned" since ive had it (1year) but i thought the ECU does that itself?
my car is fully stock, probably only spend about 20% of driving time with the bost gauge in the positive boost area.
so it would be a good idea to get some new plugs and clean the AFM?
if this doesn't work does anyone know of a good tuner arounf the liverpool area?
related threads on this topic are rampant throughout this forum, do a search and see what other people are saying....this only indicates you're not the only one who thinks they have fuel problems/issues - so is it really an issue or is it just paranoya???
imho, in sydney, because of the traffic and petrol quality i would be extremely surprised for a stock rb25 to average better than 350-380km a tank. i've noticed people from victoria with extremely good fuel consumption figures, but they dont have the traffic of sydney, they probably have better fuel & it depends on the type of driving they do...highway vs city
i have a powerfc tuned to about 12:1 AFR and i will consistently hit 400km with a mix of city/highway/full throttle. before the tune i would be lucky to get 380km per tank.
unfortunately, you can't tune your ECU as its stock. you will have to get an aftermarket fuel controller (apexi safc) or replacement ecu to do this.
how many km's has the car done? if its not time ie. 50,000 or 100,000km's you might try as everyone says, re-gapping your spark plugs, replacing your airfilter element, cleaning your AFM & replacing the fuel filter.
...but otherwise, live with it! its a 6 cylinder turbo. its a performance car. performance requires fuel. having said all this, you're still doing better, from a fuel consumption perspective, than a V8 or Rotary! :D
Hey franks, i was not complaining, just surprised, in my old 180sx (2ltr with 14psi exhaust etc) i used to drive with the throttle fully imbedded into the carpet most of the time and it still returned better figures than my skyline and this surprised me, that is all
    • Hi Apex and welcome!
    • Probably too late to reply to this, but worth a try. It's not calliper flex, the calliper as a whole is moving so it has to be calliper mounting bracket flex.  Calliper mounting brackets are designed to stop the calliper rotating, they don't need to be designed heavy duty to stop the calliper moving in and out.  Whatever it is is not the major cause of poor pedal feel, the outer pistons are moving towards the disc rotor the same amount as the inner pistons are moving away from the disc rotor.  Hence no change in fluid usage, what extra fluid is needed to move the outer pistons is recovered from the inner pistons. For a calliper to move as a whole by far the most common reason is the rotor is not perfectly centred in the calliper.  The first thing I check is that hub face is perfectly clean, bare metal, where the rotor hats contacts it.  Then I check the that rotor is firmly held in place by at least 3 wheel nuts (or equivalent). If all of the above are confirmed to be in perfect alignment then I would check the piston sizes and ensure that the 3 inner pistons and 3 outer pistons have matching diameters (eg; 28/32/36mm).  I have seen a no name 4 spot calliper that had 1 of the 4 pistons a different diameter. Maybe I missed it, are both the callipers exhibiting the same problem? I would remove the transfer pipe and inspect it to make sure that there are no restrictions. Maybe you already have but if not I would return them with the video and have them confirm all of the above.   Hope that helps Cheers Gary
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
