320-340rwkw is what the GT-SS will make when pushed. Whatever they make in and around that, is what they make and thats all there is too it.
Dont get too set on a 'figure'.
If you want a 'figure' then just play with the dyno settings, its easier and cheaper.
im not after big numbers was just woundering?
so in a r32 they could be good for 10s? with semis... :P
im going to go a sard fuel pump...
should i change to nismo afm also?
i was reading they are good for 450hp? or is not worth pushing the stockers?
also when is a hard pipe kit needed? ill be staying with the stock cooler.....
thanks in advance steve
well you can run a mid 11 on stock turbos driven hard, so i see no reason why a high 10 cannot be done
yes fuel pump
yes AFM's
Also injectors need changing
Stock piping is fine, if stock piping is fine for 400rwkw GTR's, good enough for you.
o really thats alot! thanks for that!
i just installed the sard 720s so ill do the fuel pump next and the wire mod...
then turbos and drive it softly down to get tuned with the afm hmm getting excited now :P
i ran an 11.1 @ 129mph with my r32gtr with hks gtss setup, with my mph i should have ran a high 10 but i kept it in 3rd gear across the line (on the limiter for about .5sec) dumb mistake!
im @ 325awkw but will be pushing for more once i get my forged bottom end done
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
