Having a huge cleanout of 32 GTR parts. I have got rid of a fair bit of stuff but I still have a little left over.
All parts are in Melb. Frieght at buyer expense. I will get sizes and weight for you but you have to price the freight up and I will confirm it once you actually want it.
Gauges and Electronics
Apexi Electronic Oil pressure and Exhaust temp gauges and senders with max warning $300 pair
HKS Vein Pressure Controller - Very Rare and wanted.
Deletes the need for afm's and can control fuel rates $500 Comes with looms and sensors
HKS Turbo timer $80 plugs straight into dash loom
Blitz and Mines ECU's x2 $100 each
Wheels
Nismo LMTG2 rims 17*9 with 16 offset. Perfect for a 32 gtr. 2 very good tyres, 2 unroadworthy. They have a few scuffs on the rims. $1250
Set R32 GTR rims 16*8 with unroadworthy tyres. A couple gutter rashes. $500
Set 265/35/18 semi comps. Bought off Racepace secondhand and I never used them. Still a couple trackdays in them $100
Engine/Drivetrain
Rear drive shafts $150 Good boots
Blitz external venting BOV's $175 pair with std gtr pipe to mount on.
3 GTR radiators $80 each Same as gtst.
Fuel tank with hangers/pump/sender/filler neck $200 Stop serging on your gtst as the pump is mounted a lot better.
GTR fuel pumps x2 $100 each
RB26dett crank, oil pump, rods, plus all the other parts associated with crack from 32 $400 Removed form engine that had a cracked ring. Sold head and block.
Suspension/Brakes
Tein HA height and damper shocks and springs $500
STD shocks with aftermarket springs $200
Pair machined 324mm rotors $150
Tein springs. Suit drift car $100 Very stiff.
324mm slotted disks-new, spacer kit to run 324mm disks and overhauled calipers and braided lines with heaps of set used performance pads Upgrading to big 355mm brembo's. Best upgrade you can do without spending thousands of dollars. Almost as good as GTR brembos. Same pad width just looses 5mm on height at the bottom. No brake fade running 1.23 at Sandown and 1.52 and PI or 20 min sessions running 1.10's at Wakefield with a few laps to cool engine oil down in the middle.
Will fit R32 gtst, gtr and R33 gtst
$650
Interior
Dash boards. Small boubles in front of passenger $40 each
2 sets nissan floor mats $80 each
GTR interior trims. A few small scuffs $150
Body
LH door window w/tint $40
GTR fuel cap door $50
Rear Bumper reo $60
RH door $30 bare
Big duel element aluminium wing $100
Please don't ask for other stuff as this all I have. No swaps either or low ballers. I won't get back to you if you offer stupid prices. Will budge on some stuff but no others. If you know what it looks like please don't ask for pics for silly things.
