While i haven't driven the R35, i have sat in one in Ginza.... and you are spot on about the cabin layout and finish. The 35 has a great layout and the seats/dash display are excellent. The build quality is "tip top" :) :)
Pics from the one i sat it... (and cried over when the ace salesgirl said 'no' to a test drive...)
Review was a bit "yawn" to me, nothing I haven't read in countless auto magazines. But at least you used your own photos this time!
IMO this is a better review:
http://www.caradvice.com.au/16897/2009-nissan-gt-r-review/
Congrats on getting a drive Dan. Nice article. I so know how you feel when you get handed the keys. Lol it's a bit of a moment where you can't reconcile the want to drive vs. the value of someone's pride and joy.
It was worse when a mate in Singapore let me drive his one. Over there it's a $230k USD car so it's tough to go too rough on it. I did anyway...
p.s. the LED lights are simply Nissan options not Nismo items. If they were made by Nismo the price tag would be 1.8million yen. Per side.
And they'd void your warranty if you bought your car from Nissan Australia.
Brokaz: thanks for the feedback, I'll keep that in mind for next time. Hard to really jazz up a brief stint behind the wheel at predominantly legal speeds in a privately owned car. Thought it best to just tell it like it was rather than try and make it out to be something it wasn't.
Scathing: Great image, I love it lol
Sewid: Thanks for clarification, I was a bit curious about that when Carl mentioned it but he assured me it was a Nismo item so we went with it. Keep up the good work over at GTR Blog too, I'm loving it.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
