hey guys...few questions.. just little things but yeah
1. external gate...bought one no long ago and installed it myself... although there are 2 vacuum ports... i have only one connect (the middle one ) to my cooler piping but there is another on the end of it.... i read somehwere that the other goes to the plenum... but in that case which hole?? but yeah i kinda dont understand..there was a forum topic on it but none of the pics worked ect.... so yeah i htink the one i dont have connected is the one on the diaphram.. but the car holds boost fine and everything.. so yeah
2. gapping my plugs atm.... and i know i am supposed to have them at 0.8 mm ...but i have a gapping hting and the closests is 0.813 ?? ... am i being fussy?? or should i change that ??
3. i recently blocked off my BOV ( with a rubber plug and a cap hose clamped on) but i was wondering... is it poosible for the rubber plug to be sucked in or sumthin and then pushed through to the engine??... i know that sounds highly unlikely but.. just image if that happened!! also.. the BOV had a vacuum hose to the plenum which i also blocked off.. if the wastegates hose does go to the plenum could i put it where the BOV hose was??
thanx guys i know its a stupid post but sumtimes i jhust wanna sort things out
thanx all
alex
https://www.sau.com.au/forums/topic/240456-questions-on-the-old-skyline/
1. hose goes to boost controller, it holds boost fine, but it wouldn't be dumping.
2.nothing to worry about, if its running fine, its running fine.
3. use a metal plate with sealer [if I understand the question]
whgats dumping..could ya expand any more?? kinda clueless here
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
