The author from that article, Ross Catanzariti is an old school friend of mine who i still see regularly as he is one of my brothers best friends.
ill see if i can get my hands on this device and check it out. hes a lucky bastard he gets to try all the good and latest gadgets for free and writes reviews for them on good gear guide.
only a 1gb hdd, meaning you'll either have to have a separate DVD headunit or plug an external HDD with all your movies on there...still a lot of wires cluttering the dash I reckon coz its still mounted on the windscreen. Would be good if it was able to be intergrated into the double din space but from the looks, its a tad too big.
u can slot a SD card in there, and those things can go upto 64GB!, thats more than enough to put like 20 hours of video
Im thinking of getting a DVD head unit, I got quoted 600 bux, only problem its some taiwanese brand =(, it got ipod connection though
Are you referring to this???
Pioneer AVIC
If so, looks pretty promising...
Chris any comments?
seen these at autobarn. could be integrated into the dash with fiddling though it would require removal of the OE screen/system. in th cases of cars that I have done it would remove whatever I have done to the car.
the HD3 would do nicely but would require a dash swap to make it work.
in all they are not a bad unit. navi is quite accurate and quick to correct when you make a mistake. BT is good as well.
(all this is based on th HD3.)
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
