Don't be weak Lee. Cram 17-18psi in to it. :down:
I run a 1bar actuator on my Garrett spec HKS equiv (GT3076r .82 IW) with a bell mouth dump. It tails boost off to 17psi preventing it from making any more peak.
An 18 psi actuator (which should allow 20-21psi) is coming, then I'll eventually get around to fitting it so that will 'should' sort my problems. :ninja:
When's the tune?
  • Replies 143
Don't be weak Lee. Cram 17-18psi in to it. :D
An 18 psi actuator (which should allow 20-21psi) is coming, then I'll eventually get around to fitting it so that will 'should' sort my problems. :D
When's the tune?
Hey cubes how are ya mate. I'm hoping to run 16-17 once tuned which will hopefully be within the next 2 weeks as i'm still waiting on injectors and pump.
If your cramming more boost into your beast you obviously don't like traction 3LTR plus 20-21psi = Lots of torque and wheelspin :P
Traction isn't so bad with the GT3076 .82 on the 3ltr as boost is made pretty much off idle so the power delivery is linear and relative to the throttle.
It doesn't have the lag/doughy feel then bang on to boost sort of feel. More so like a factory turbo setup.
+ better tyres, better suspension setup = more grip = the ability to turn the wick up. :P
As it is now I can get it to hook up fairly well if i want to or I can simply let it rip until I grab fourth. Its all in the right foot. :D
Do you have the .6 or .8 rear on the ProS?
Your beast must be one of the best sleepers in Adelaide. I have the .6 rear ProS, should be well suited to the 2.5 litre i'm hoping.
The .6 will come on hard. :P
Be sure to throw some good tyres at it and angle the front of the cradle down. :D
The RB30det's now done 100,000km's so I'm itching to build up a high comp (9.5-10:1) GT35 or twin 2530's that runs on E85 and drop it in to a cheap GTS4. :D
Yeah i'm hoping it's more suited to a daily driver than the .8 rear.
I'm actually running 265 rears now so tyres are at their optimum. When i purchased my coil overs the guy threw in some donuts for the diff cradle might pay to fit them up me thinks. Twin 25/30's sounds like a bit of fun in a GTS4 plenty of traction. Whats the advantages of E85 more octane ?
Ryan... I'd be suprised if the GT35r .63 came on hard in the low 3000's on the RB25 when driving.
The turbine map shows the GT35r .63 has the same flow/pressure as the GT30 .82. The GT30 .82 on the road with a 25t comes on hard closer to 4000rpm.
At a guess I'd expect you to feel a hard shove in the back by 4k in second gear and 3.6-3.7k in third gear. :P
Sounds like it should be a good package Lee, Probably simular power to what i had, but my top end trailed off a fair bit. Im hoping my .63 reared gt3582r will come on hard around 3-3200rpm. I will miss the response of a turbo like the ProS
Cheers Ryan i'm hoping for a nice all round package out of it. I'll be more than happy with 250rwkw at 14psi doubt it very much tho. Good luck with your new set up mate sounds good.
i dont thikn u will be able to get much more out of the GT3037S then 300rwkw. I think mines about done at the power its making now. Then again it could be the rear housing or the injectors letting me down.
Have fun and thrash the crap out of it legally.
great turbo to have purchased.
I have one on my JZX81 1JZ-GTE. awsome torque and great power throughout the rev range.
Mine makes around 290+rwkw on 16psi.
Then again my engine has a few more toys inside and out.
Will be keeping an eye on your posts to see what you get out of it with Martins skills behind it.
Goodluck
Hey brentogs - you gained some more killerwasps??? i thought it was only making 260's rwkw...(going by your FS thread)?
BTW - My RB24DET + GT3076r IW .63 is making 275rwkw and mate with a S14 with RB25 + GT3076r .63 external gate just made 308rwkw at about 18psi i believe - at MORPOWA
Edited by huddy
275rwkw is nothing to be sneezed at well done your beast is obviously a well sorted package. What mods is your mate running with the RB25 (has he done head gasket forged internal etc).
cheers
Lee
yeah i think he has 6 boost manifold, greddy plenum, forged pistons, metal head gasket, rb25 intake cam replaced for rb20 intake cam, running a rb20 ecu remapped. (nistune remap i think - tuned by simon at morpowa) - on pump fuel. 550 inj, 044 pump...
i may be able to get a little more i think - i'm going to change my injectors, because the gtr ones are maxed atm, so had to raise the fuel pressure.
Your mate has definately spent the money on making the power thats for sure. What injectors are you going to upgrade to nismo 555's or similar?
Joel, that's a fair effort in a few short years. I'm impressed! If I recall correctly, you had your RB30DET built a little while after my 2.5L. In that time I've covered some 5,000km, if that. Admittedly 2 of those years it did more travelling on the back of flatbed trucks - thankfully by choice, whilst undergoing various modifications.
A .6 housing on a manual RB25DET is 'wheel-spin city', even with good tyres. It can be fun though.
My Stage 3 0.63 Turbonetics rear housing comes on hard, really hard, in the low 4000rpm range - even a traction friendly diff' angle and camber set-up won't stop the 275/40/17 MT ET radials from rotating faster than their cousins up the front.
The HKS 3037 Pro S 0.68 housing will mean you'll have plenty of fun in 2nd gear during daily driving use - nothing the right foot can't control though. The 0.87 housing would be my personal choice, due to the extra top end power potential, but that's only because I wouldn't use it as a daily driver. The 0.87 is good for ~310-320rwkw.
Also, I'd agree with you, Joel. The GT3540 0.63 on a RB25DET will probably see peak boost by ~4000+ (in 2nd). It should also provide the kind of torque curve that produces 3rd gear wheel-spin. I like 3rd gear wheel-spin, it's nice :(
The .6 will come on hard. :)
Be sure to throw some good tyres at it and angle the front of the cradle down. :sick:
The RB30det's now done 100,000km's so I'm itching to build up a high comp (9.5-10:1) GT35 or twin 2530's that runs on E85 and drop it in to a cheap GTS4. :/
Wheel spin city sounds fine to me so long as its right foot adjustable. I must admit the quickest Skyline i have actually been in to date was an R32 with 240rwkw (RB20DET) not sure what the mods were but that thing used to be pretty impressive. So if my beast churns out 250ish on Martins dyno i will be more than happy.
Well i receiverd my pump and injectors today (was hoping to have them Wednesday). The car is getting tuned on Monday at Willall wish me luck.
haha nice work man, ill see ya at Willall on Monday aswell, My car's done now just waiting for monday...
280-300rwkw here i come
Edited by Ryanrb25
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
