Johnny - I disagree 15w is too thick for a turbo, if you heard metal grinding on the turbo like you posted I'd say it';s a fair chance you had stuffed turbo bearings that would not be caused by the weight of the oil (cheap oil maybe?). I have run a 300V 15W-50 thru my pair of HKS 2530s for 5 years and they are both in perfect working order.
Hey man, my experience was on an s15 with a t28 so might be a bit different??? I had some motul 15w50 and when i put it in the turbo made a 'metallic rattle for a few seconds'
next morning it did the same thing and the car would be hesitant to rev when i drove it.
Immediately switched to a 5w40 and problem solved.
I didnt know 300v made a 15w50; is it any good? hows it on coldstart?
  • Replies 43
castrol edge is rubbish imo. they spend a shitload more on marketing and BS advertisments than they do on making good oil. the cheap motul oils like turbolight are rubbish. the 300V is 100% synthetic ester and is head and shoulders above anything else i've used. it's the top of the tree. most of the other so called synthetics are not a full synthetic and are blended rubbish.
i put 300V in the legacy GT (JDM liberty GT basically) my mum drives! i put it in the lowly silvia which makes 230rwkw and needs a decent oil as it's running a trust turbo kit which relies on the engine oil for turbo lube and turbo cooling. and I have used it in the GTR(s) from day 1. never had a problem with any of them. I even did a UOA (used oil analysis) some time ago and the results were good. :D if you care about and value your engine 300V (in the appropriate weight) is the way to go. and the myth about it not lasting long as it's a race oil is rubbish. it's just a very good oil and will last longer than a poor one and still have all it's great properties (high film strength etc).
  • 1 month later...
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
