Wrecking R32 Gtst Vic
i have decided to wreck my r32 gtst :kiss:
everything and anything from the car is for sale if its not on the list jus pm or call me and make an offer
mobile: 0401787434
rb20det with after market turbo and ecu $1000 85k supposed to have internal work
auto trani $150
diff $150
side mirrors $100
4 doors rear right damaged $150
keys & barrel set $200 (ignition, doors, boot)
rear bar $50
rear reo $50
a/c condensor $50
wiper motor $10
all seats inc door trims $350
roof lining $20
interior lights $10ea
sunvisors $20pair
interior mirror $30
front windscreen pillar trims $30
rear upper trims-$20
skyline side step trims $30
center console $30
glovebox $30
dash $50
cluster surround with gauges $80
brake setup $200 rear has brand new pads
steering column surround $30
carpet $100
under dash trim $20
all seatbelts $120
fueltank $80
bilstein drift suspension $300
steering column $50
rear cradle $100
metal dash support $20
body wiring loom $120
engine bay wiring loom $90
power steering rack $100
skyline floor matts $30
climate control $30
all dash a/c vents $100
brand new borg performance fuel pump in box $100
tail lights $30
boot lid $20
windscreen $50
rear windscreen $50
wm intercooler and piping $60
3" turbo bak zorst $200
boost controller and boost gauge $50
18" work rims with potenza tyres $1000 o.n.o
17" work rims w tyres 1 buckled rim $200 o.n.o
most prices are negotiable as i need to sell at least 2k worth
to buy a sh#t box for work a.s.a.p
Edited by Striker86
  • Replies 51
awww damn 4door....dont they they fit a coupe
yes they should fit the coupe i was going to put the coupe lights on mine
and they looked identical also my mate has the coupe lights on his 4 door so cant see why
couldnt do the other way round
Hmm you sure?? Im 99% sure that they are totally different. You could modify them to fit, but without modifying I dont think they'll fit dude.
SOLD
boot lid
front seat belts
indicator lever
tail lights
transmission
dont really no to much info on turbo and suspension
where already on car when i bought it
all i no is i loved the suspension made the car handle like a go kart
and turbo ran sweet no too much lag from 2900rpm
jus jumped through revs
car had alot more balls than my mates stock standard r32 turbo coupe
also not sure if ecu has been tuned or anything though theres nothing wrong with it
i think its a standard one but dont quote me 100% on that as i wouldnt know the differance
and only damage engine sustained from accident is a broken fan and broken power steering pulley
other than the 2 things is a1 thank god
i am located in sunshine
What does the brake setup include? Assuming calipers and rotors front and rear, are the front calipers 4pot?
yeah brake setup includes calipers rotors and pads
also the lines if u want them
not sure if are 4 pot im pretty sure they are standard setup
 Share
    • Weird the Gktech one doesn't have the 3 holes and is only a 5min install if you have the standard front bar.
    • Honestly, as someone on the standard PS4 controller, should be relatively easy to get gold. Remember you have more grip than you think.
    • Fitted some Advan AD09s to try next. Likely slower than the CR-S but should work in the wet and last longer.   Off for alignment and the new plates worked a treat! I was finally able to hit both my drift and grip alignment targets with the same setup! Grip Front: Toe total -2mm(1mm out each side) Caster +7° Camber -3.8° Ackerman +15° Rear: Total toe +3mm (1.5mm in each side) Camber -1.5° —————————————- Drift as above but drop the front sway bar and change the below. Front: Toe total -10mm(5mm out each side) Ackerman +5°
    • @Duncan can you put the Link in, and measure all the power input voltages with a multimeter. Specifically looking for one that is low.   Then put the other ECU in that it runs on, and measure those voltages again with a multimeter?   If all of your voltages read normal on both ECUs, but the link is still reading low internally, your issue IS the LINK. If the voltages drop low on the multimeter while the Link is plugged in, but not other ECU, then the issue COULD be wiring in the car, or it COULD be the ECU. To rule out wiring, work out how with an ECU removed, you can trigger all the necessary relays, and then measure resistance from the pin that is reading low at the ECU, to the batteries positive power.   I have a sneaking suspicion your issue is the link, it's not reading the voltage properly, possibly a dry joint, or a Cap dieing, and because voltage is low, it's likely attempting to compensate on fuelling and the engine won't run.
    • Hi there, Does anyone here have the carbonetics slam panel installed on their R34 GTT? Or used to have one and got some pics of how it sat? https://carbonetics.net/products/1999-2002-nissan-skyline-r34-gtt-cooling-slam-panel?srsltid=AfmBOoo6Uz0nuxGI3qC0sn56KJI6PMgh0OvV-pbegsPDHTtTxz4IMljc I’m just trying to get an idea of how they sit once installed but these guys have no pics.  biggest question I’m trying to figure out is what the hell the 3 holes at the front of the panel are 😂 and where they bolt    Thanks in advance
