Skyline V- series and 350Z Meet and Greet Sausage Sizzle fest
Date: Sunday 30th November 2008
Time: Sausage Sizzle to begin at 12.30pm (staff and event co coordinators will be there at 11am)
Location: Bodyform Motorsports Unit 5, 46-48 Jedda Road Prestons NSW 2170 (closest cross st - power drill) map here www.bodyformaero.com.au
Lunch Sizzle: We shall supply Snags, bread, condiments, serviettes and drinks. Coin donation appreciated. Feel free to bring your own also.
Afternoon Cruise: approx 3pm. Depart from Bodyform > Cordeaux Dam > Home
Directions: Exit Jedda Road onto M7 (require E Tag). Heading South onto Princess Highway. Picton Road Exit. Right turn at Cordeaux Dam. NO Traffic lights!!
Behavior: This is a private car park, there MAY be other tenants using the facilities. Please refrain from any idiosyncratic driving inside the complex. Keep all areas clear of rubbish, respect other tenants property. Park in allocated parking spaces.
Also attending : HPI magazine - Motul – Giveaways – Pole Dancing Course + more TBA (V35 Driver to update)
Brief: Expect a casual fun day out, talk shop, look over some nice rides and meet various personalites. Enjoy yourselves and just grow this V series community. >_<
Please add your name and attendees so we can cater for it.
More info TBA- we'll just get the date up for now.
Can a mod sticky this please.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
