ing if i well after pulling my battery out for a charge i notices its only 370 CCA battery,
it normally takes 3/4 seconds to start, i am wondering if i need a bigger battery
x0x0x
Is that 3/4's of a second to start or 3 - 4 seconds to start?
I run an 'AllRounder' from Battery World in Fyshwick. Cheaper and has more punch than the typical Yellow Tops. It takes around 1/2 a second to 3/4 of a second to crank the engine over. The CCA on it I think is around 600CCA with a higher AH rating than the yellow tops. AllRounder Battery
cheers mate,
i ment 3 to 4 seconds,
I see the slightly longer start as a good thing. It gives the engine a little extra time to build oil pressure before being under full load... not a biggy for a standard engine, but it all helps.
Whatever Optima Yellowtop is. It's a deep cycle battery, meaning the charge level can drop to pretty darn low levels (ie won't crank at all) and still be recharged to normal :D Might come in handy Alex!
Whatever Optima Yellowtop is. It's a deep cycle battery, meaning the charge level can drop to pretty darn low levels (ie won't crank at all) and still be recharged to normal ;) Might come in handy Alex!
Same goes for the AllRounder I posted about Ben.
I had the Yellow Top in the Subie.. Excellent battery, but not for the price.. I got the AllRounder for half the price and it has a longer deep cycle charge.
(P.S - I just realised I said Battery World, but it is suppose to be "The Battery Factory")
Edited by sfrizza
I had a 440cca battery and it took maybe 2 seconds to start the motor, once that battery started to die (Scott - remember us roll starting my car in Kingston on Anzac day ;)) I chucked in a Supercharger brand 660cca battery. The fellow at battery world said it's the same cold cranking amps as you get in a Landcruiser.
One tap of the key and she fires first time every time, it's a good feeling lol :)
I can't even tell what mine is.... It's blue with yellow bits on top. It died one day and the NRMA told me it was f*ked and I really had to get to work so the NRMA dude in the battery van came along and changed it for me.
*shrugs* it works ;)
I had a 440cca battery and it took maybe 2 seconds to start the motor, once that battery started to die (Scott - remember us roll starting my car in Kingston on Anzac day :)) I chucked in a Supercharger brand 660cca battery. The fellow at battery world said it's the same cold cranking amps as you get in a Landcruiser.
Yes i do.
Since running a oil cooler, i am paranoid about building pressure, so ignore me. :P
660cca is uber, will do the job fo shiz
yeh but i have that on my Landcruiser just to power accessories and a winch, must be some serious stereo to need as much battery power as that. :D
Mostly hidden. Some nice quality speakers in the rear and front doors with some Xcellent tweaters.
Work done by AudioTech Tuggers.
Put them in the GTS-T and then moved em into the GTR.
Edited by Sinista32
holy crap what size subs are they? my 12 doesn't take up anywhere near that much space
Could be the angle of the Photo's and the fibreglass sub enclosures. I cant fit much in the boot :P
2 x 12.5" Bostons = Heaps of DOOF DOOF (bass).
I dont turn it up till on the open road or at SAU Christmas party's at the Cotter. Sometimes it annoys me to hear it from cars round populated areas like the malls or local shops (fully sic mate!). I just think what a wank. A nice Skyline will get noticed anyway.
Most of the sound is restricted to the inside due to soundproofing from firewall to boot.
i went with a big 600cca cheap bosch and it works great
but 1100cca? thats nuts. what do you need that for? starting on a cold morning while doing a bit of arc welding at the same time?
hehehe I don't do things by halves :P
Errr - 2 Battery's. 1 to crank and the other to keep the stereo cranked.
I used to do that, to set it up right (and legally) there's a lot of shit involved.
Ooooh nice...
This is why I need the power :( and you can see that even though they call them a 'twelve inch sub' they obviously don't fit in a 12 inch hole :)
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
