ing if i well after pulling my battery out for a charge i notices its only 370 CCA battery,
it normally takes 3/4 seconds to start, i am wondering if i need a bigger battery
x0x0x
Is that 3/4's of a second to start or 3 - 4 seconds to start?
I run an 'AllRounder' from Battery World in Fyshwick. Cheaper and has more punch than the typical Yellow Tops. It takes around 1/2 a second to 3/4 of a second to crank the engine over. The CCA on it I think is around 600CCA with a higher AH rating than the yellow tops. AllRounder Battery
cheers mate,
i ment 3 to 4 seconds,
I see the slightly longer start as a good thing. It gives the engine a little extra time to build oil pressure before being under full load... not a biggy for a standard engine, but it all helps.
Whatever Optima Yellowtop is. It's a deep cycle battery, meaning the charge level can drop to pretty darn low levels (ie won't crank at all) and still be recharged to normal :D Might come in handy Alex!
Whatever Optima Yellowtop is. It's a deep cycle battery, meaning the charge level can drop to pretty darn low levels (ie won't crank at all) and still be recharged to normal ;) Might come in handy Alex!
Same goes for the AllRounder I posted about Ben.
I had the Yellow Top in the Subie.. Excellent battery, but not for the price.. I got the AllRounder for half the price and it has a longer deep cycle charge.
(P.S - I just realised I said Battery World, but it is suppose to be "The Battery Factory")
Edited by sfrizza
I had a 440cca battery and it took maybe 2 seconds to start the motor, once that battery started to die (Scott - remember us roll starting my car in Kingston on Anzac day ;)) I chucked in a Supercharger brand 660cca battery. The fellow at battery world said it's the same cold cranking amps as you get in a Landcruiser.
One tap of the key and she fires first time every time, it's a good feeling lol :)
I can't even tell what mine is.... It's blue with yellow bits on top. It died one day and the NRMA told me it was f*ked and I really had to get to work so the NRMA dude in the battery van came along and changed it for me.
*shrugs* it works ;)
I had a 440cca battery and it took maybe 2 seconds to start the motor, once that battery started to die (Scott - remember us roll starting my car in Kingston on Anzac day :)) I chucked in a Supercharger brand 660cca battery. The fellow at battery world said it's the same cold cranking amps as you get in a Landcruiser.
Yes i do.
Since running a oil cooler, i am paranoid about building pressure, so ignore me. :P
660cca is uber, will do the job fo shiz
yeh but i have that on my Landcruiser just to power accessories and a winch, must be some serious stereo to need as much battery power as that. :D
Mostly hidden. Some nice quality speakers in the rear and front doors with some Xcellent tweaters.
Work done by AudioTech Tuggers.
Put them in the GTS-T and then moved em into the GTR.
Edited by Sinista32
holy crap what size subs are they? my 12 doesn't take up anywhere near that much space
Could be the angle of the Photo's and the fibreglass sub enclosures. I cant fit much in the boot :P
2 x 12.5" Bostons = Heaps of DOOF DOOF (bass).
I dont turn it up till on the open road or at SAU Christmas party's at the Cotter. Sometimes it annoys me to hear it from cars round populated areas like the malls or local shops (fully sic mate!). I just think what a wank. A nice Skyline will get noticed anyway.
Most of the sound is restricted to the inside due to soundproofing from firewall to boot.
i went with a big 600cca cheap bosch and it works great
but 1100cca? thats nuts. what do you need that for? starting on a cold morning while doing a bit of arc welding at the same time?
hehehe I don't do things by halves :P
Errr - 2 Battery's. 1 to crank and the other to keep the stereo cranked.
I used to do that, to set it up right (and legally) there's a lot of shit involved.
Ooooh nice...
This is why I need the power :( and you can see that even though they call them a 'twelve inch sub' they obviously don't fit in a 12 inch hole :)
    • Hey all just wanting some advice. I’ve just compression tested my RB25det and these are the following results  Cyl 1 - 135psi Cyl 2 - 135psi Cyl 3 - 120psi Cyl 4 - 140psi Cyl 5 - 130psi Cyl 6 - 125psi   do these numbers seem ok.  Thanks in advance
    • I must say - this is how I picture all R31s!
    • Rust repairs completed, doors back on! pretty much totally back together running now. All future repairs will be fiddly wiring getting everything back up to road condition.  hasn’t  taken that long considering the condition I got the sub. note my helpers keeping the back seat warm 😂
    • SAU NSW Old Pac Cruise to Newcastle All Japan Day 2025 Sunday 27th July 2025 5:00AM Meeting Berowra Station Commuter Car Park 2 5:15AM Departure Cruise Via Old Pacific Hwy 7:45AM Arrival to Lambton Pool (Regroup) 8:00AM Arrival to Newcastle All Japan Day 2025 Meet Location: Berowra Station Commuter Car Park 2 Stop 1: Lambton Pool (Carpark) Final Destination: McDonald Jones Stadium for Newcastle All Japan Day 2025 Tickets: Newcastle All Japan Day 2025 $20 Per Car Spectators Free PURCHASE TICKETS HERE *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • SAU NSW Attends Machines & Macchiatos Cars and Coffee Sunday 13th July 2025 7:00AM Meeting Davidson Park 7:20AM Departure 7:45AM Arrival at Northern Beaches Christian School Meet Location: Davidson Park Final Destination: Northern Beaches Christian School Machines & Macchiatos Tickets: $10 Per Car $2 Spectators Pay at Gate LIMITED SPACES Register Below to Reserve your Spot. Members Receive Preference REGISTER HERE   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
