I got my r32 with a rb25det tuned today.
I am in strong belief that the tuner did a good job as i have dealt with him on many occaisions but he has said that my fuel ratio is all over the shot. He said he has not seen something this bad in ages.
The mods are
FMIC
Walbro 255 fuel pump
Sard FPR
3'' exhaust from turbo back
Possibly a neo turbo on it.
Running 10psi i was getting 185.5 rwkw.
Now after the tune all he did was check the mixtures as i was getting massive flames of over a meter lapping my boot and he checked the boost running 11psi i get 183.2rwkw.
Does this power figure add up as in the top one is that what a rb25 will make roughly with those mods. He told me i will get prob another 10-15rwkw fixing the fuel mixture and getting it to run properly.
He has stated that normal driving around town it is so rich that i will glaze my bores. But WOT at 3000rpm it leans right out. Then goes rich as hell again untill the fuel pump runs out of leggs and i lose fuel pressure but if still runs righ cos of all the fuel in there. Any suggestions would be good or if you have had this problem. He said the lean spot is pretty bad but has advised me that he swapped A/F meter, o2 sensor and played with the TPS. But none of this changes anything.
He reckomends i get a microtech as it is a full wire in job as he want to do a new loom and eliminate the prolems with in it.
Have any of you had similiar problem at all and if yeah what was it or what might it be.
https://www.sau.com.au/forums/topic/240535-car-tuned-today-and-not-to-happy/
  • Replies 49
It's about right.
180 to 220 kw is the spread for thise mods, depending on dyno, air temp, blah , etc
Look at getting an ECU mod, whether it be a pigyback like safc or emanage, or full replacement like pfc or vipec, blah , etc.
Generally, the more you spend the better.
I dont see any mention of ECU...
And later you make mention of one... so im going to assume you do not have a proper setup/tuneable ECU...
So, how on earth did he tune it?
Where is the dyno graph with AFR plots?
That might tell a better story as im not taking all your saying as 100% right, i think something might be missing
Either way, end of the day, the power sounds exactly right for those mods on a stock ECU. AND generally most stock ECU's have a fit with increased boost, and your setup falls perfectly into that category thats common as it gets.
Like R31 says, you need an ecu, then you can set up your fuel map (with a tune), go from 300km a tank to 500, and probably make another 10-30kw as well. Without an ecu your just wasting $$$$ on loosy tunes and fuel. Can't believe how many people don't do this, its a basic fundamental part of the mod list.
Do your engine and your bank account a favour. Buy a Power FC.
Then maybe you won't blow your engine up!
But hey, your on a internet forum.. your here to ask for advise and then go off and do the complete oposite.
Thanks for the replies. I have a sotck ECU at the moment and wanted a power FC. Was ordering one next week but he has asked for a Microtech as that is his prefered computer so he can eliminate alot of sensors and shit such as the AFM.
He has swapped the AFM over twice noe to different ones and it has not helped it is still runnin 4.9-5 volts.
Thanks again i will go Buy a ECU. The car is in a garage and not moving till this is fitted.
Cheers Guys.
Pfc is the most plug and play of the ecu's, and is easily enough for almost any street application... Its also the most common is very reliable and there are tuners everywhere. It also runs all your cars bits and bobs like climate control etc etc :(
your fuel pump should not run out of leggs at that Kw.... I'm running 335Kw with the same pump...
i haven't heard many good reviews on microtech, go for a PFC or Vipec or if your going to go all out on mods later on get a haltech or something...
I'll give you some advice from the benefit of my experience. your problem is most likely the walbro fuel pump. I can't even begin to total up the number of people who have fitted one only to have problems with car running rich, then lean etc. the chances of it being the fuel pump double if you installed it yourself.
microtech is NOT the way to go for your skyline. it is far easier, cheaper and better to buy a Power FC and fit that. anyone can tune it. if he can tune microtech he can tune power FC. if not, go somewhere else.
and get that walbro pump out of there and fit a direct fit nismo or tomei pump. they will supply plenty of fuel for even 300rwkw and are a direct fit into the take so there is no chance you can balls up the installation. also, why did you install the sard fuel reg? and what have you set it at? this could be contributing to your problem. if you sell the sard reg and the walbro pump that will probably cover the cost of a new nismo pump.
+1 for Power FC over Microtech, I've had a microtech in my old car and although it made the power it didn't drive particulaly well. My dad has a Power FC in his car and it drives smooth as a stocker.
Microtech are great ECUs for motorsport applications but do not have the tuneabillity of a Power FC. For a daily driven car that you want to drive like standard, cold start and cruise, power FC is the go. The fact that it doesnt run idle air control, knock, are two reasons i wouldnt use one in a street car, and i have fitted over a dozen before Power FCs were available,
had a microtech once upon a time
1.1k ecu
500 wire in
500 tune
+ misc
Just over 2k
better to plug n play a Power fc for Vipec more features etc
microtechs a very basic ecu which aint to flash either
OK the reason he wont use a power FC is because he want to wire it in himself. He has done many of these and has very good results with them on several skylines up here. Here being Darwin.
We were going to put a power FC in untill he looked at some of the wiring and the stock loom. He says it is mesy and well i will agree with that. So he wants to start from scratch and piss off all i dont need. I am well aware that the fuel pump i have got will support the power were thinkin it might be faulty. We fitted a FPR because the old Malpassi one i had was leaking so i got this one.
Thanks for the reply's i see it is the engine management is the problem so i will be ordering one next week. Thanks for the replies.
A PFC doesnt require any wires!!!!!!!!!!
unbolt old ECU, bolt in new ECU... i fail to see how 'messy' stock wiring is causing a problem... you dont need to change anything.
Why he would want to butcher it up, and put in something thats inferior... is beyond me
EDIT: your also running a FPR on a stock ECU setup... why?
stock FPR = fine
Gota say here that stock wiring over many years of being butchered up with all sorts of shit spliced into it can be messy and can cause problems so I can see why the tuner wants to start from scratch here.
Ive got a headache of a wiring mess and one of my brand new o2 sensors just isn't reading at all. You can see all sorts of splicing has been done on the wiring harness
DO NOT get a microtech... They are sh*t... THe car will never run properly. AFM's are VERY good for a street driven car. When tuning with one you can make it drive much nicer. You have no need to remove the afm particulary with the little power you have.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 馃憤
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
