  • Replies 49
Whats the economy like?
Compared the car with another to see if they run the same?
Around 350-475 depending on how i drive....
Forget your tuner, should of got a vipec... :yes:
HAHAHAHA thanks for the input but i will stick with what i got now.
which place did you get your car tuned at, your in WA right?
Nope in Darwin. Got it tuned at High Tech Tuning. Pretty much the only good tuner up here.
Some tuners actually know how to tune the Microtech to still retain normal economy. The problem is, most just tune the full tilt side of it.
Yeah he made sure i got good AF's the whole rang as i asked him to set it up as i was only getting around the 180km mark before the computer
definately change tuners!!! if no other tuners nearby i would check fuel pump fuel delivery, fuel pressure reg operation obvious stuff which he should know..............
fark my bro inlaw gets 550-600km with 230rwkw. hell i get 460km with 500rwhp got 520km/tank comin back from melbourne to sydney with a basic tuned motor i bought from Ice Performance.
what are ur afr's?
im not sure but do microtecs run an o2 sensor, my bros old rx7 never did.
ben...
even a quarter way up on the knock scale is bad. the only thing you have in youre favor is the engine doesnt make enough power to damage itself with the knock readings you have, standard ignition map totally wrong for that application. suggest check knock sensor wires, replace knock sensors, then alter the ign map to something more acceptable and fourthly change tuners!!!!!!!!!!!!!1
Do you ever read a whole thread before you post a comment?
thats twice now you have put your fingers in gear before your brain which represents 20% of your posts.
Edited by W0rp3D
off the topic but to answer youre comment, yes i do read the thread before posting. the guys asking people to comment on his tuning issues. i have offered advice as he obviously doesnt have confidence in his tuner otherwise his tuner would have found the problem.!!!! at least i offered my opinions alot more than you have done for him. give me a call if you need to discuss any further would be pleased to debate it with you 0883916125.
  • 1 month later...
Amazes me when people write on a forum asking for advice from obviously experienced people and then they do totally the opposite to what they are advised :D WTF
From reading this post three things are pretty clear
1) Not many like or recommend the microtech.
2) Almost all recommend PowerFC
3) A certain tuner insists on using the Microtech
hmmmmm.........
Question - it was a month ago it was all sorted is it still running ? running well ?
Secondly I would hope your tuner has a strong business that will be around for a while ( like the life of your car ) or you may have trouble around darwin ie: getting a retune in the future....
DARWIN WEATHER + MODS + HIGHER BOOST + SUSPECT FUEL + ENTHUSIASTIC DRIVING + NO KNOCK SENSOR......= :banana:
I honestly hope nothing does go wrong..... I wouldnt wish that on anyone but I just dont understand why you would go against what almost everyone recommended.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
