  • Replies 49
  R31Nismoid said:
Whats the economy like?
Compared the car with another to see if they run the same?
Around 350-475 depending on how i drive....
  Finchy33 said:
Forget your tuner, should of got a vipec... :yes:
HAHAHAHA thanks for the input but i will stick with what i got now.
  Pattygtst said:
which place did you get your car tuned at, your in WA right?
Nope in Darwin. Got it tuned at High Tech Tuning. Pretty much the only good tuner up here.
  MBS206 said:
Some tuners actually know how to tune the Microtech to still retain normal economy. The problem is, most just tune the full tilt side of it.
Yeah he made sure i got good AF's the whole rang as i asked him to set it up as i was only getting around the 180km mark before the computer
definately change tuners!!! if no other tuners nearby i would check fuel pump fuel delivery, fuel pressure reg operation obvious stuff which he should know..............
fark my bro inlaw gets 550-600km with 230rwkw. hell i get 460km with 500rwhp got 520km/tank comin back from melbourne to sydney with a basic tuned motor i bought from Ice Performance.
what are ur afr's?
im not sure but do microtecs run an o2 sensor, my bros old rx7 never did.
ben...
  darren lewis said:
even a quarter way up on the knock scale is bad. the only thing you have in youre favor is the engine doesnt make enough power to damage itself with the knock readings you have, standard ignition map totally wrong for that application. suggest check knock sensor wires, replace knock sensors, then alter the ign map to something more acceptable and fourthly change tuners!!!!!!!!!!!!!1
Do you ever read a whole thread before you post a comment?
thats twice now you have put your fingers in gear before your brain which represents 20% of your posts.
Edited by W0rp3D
off the topic but to answer youre comment, yes i do read the thread before posting. the guys asking people to comment on his tuning issues. i have offered advice as he obviously doesnt have confidence in his tuner otherwise his tuner would have found the problem.!!!! at least i offered my opinions alot more than you have done for him. give me a call if you need to discuss any further would be pleased to debate it with you 0883916125.
  • 1 month later...
Amazes me when people write on a forum asking for advice from obviously experienced people and then they do totally the opposite to what they are advised :D WTF
From reading this post three things are pretty clear
1) Not many like or recommend the microtech.
2) Almost all recommend PowerFC
3) A certain tuner insists on using the Microtech
hmmmmm.........
Question - it was a month ago it was all sorted is it still running ? running well ?
Secondly I would hope your tuner has a strong business that will be around for a while ( like the life of your car ) or you may have trouble around darwin ie: getting a retune in the future....
DARWIN WEATHER + MODS + HIGHER BOOST + SUSPECT FUEL + ENTHUSIASTIC DRIVING + NO KNOCK SENSOR......= :banana:
I honestly hope nothing does go wrong..... I wouldnt wish that on anyone but I just dont understand why you would go against what almost everyone recommended.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
