hi guys,
i had my FMIC installed on tuesday and now whenever i hit full boost (10-11psi) the turbo emmits a really high pitched whine..
obviously the problems between the rb's and the 1j's will be different but the issues would definatly be similar with regards to turbos,
any and all information is much appriciated
cheers
nerm
https://www.sau.com.au/forums/topic/240553-turbo-issues/
Best case scenario - you have a boost leak somewhere, check all of your silicone joiners, hose clamps and vaccum hoses on the intercooler system. Tighten them all and make sure that they are all sealing perfectly.
Worst case scenario - your turbo is on the way out. When a turbo squeals on boost it usually means that the compressor fan is damaged.
Example:
https://www.sau.com.au/forums/topic/240553-turbo-issues/#findComment-4201121
I had no signs.... I just took off at the lights one day and the car spooled down faster than it spooled up and from there it just had absolutely no go whatsoever.
My ceramic exhaust wheel was found shattered into about a million pieces in the cat. Turns out the other turbo wasn't too far away.
Note to self, 20 year old stocky turbos don't like lots of boost :(
But turbos dying are a double edged sword. Bad cause it's expensive but awesome because you get more power!!!
https://www.sau.com.au/forums/topic/240553-turbo-issues/#findComment-4201294
yeah it would be a leak as myn had the same thing after putting a boost controller on it turned out that the idiots at DTS but brass bolts on the zoorst housing to hold the turbo on i mean seriously wat idiots
https://www.sau.com.au/forums/topic/240553-turbo-issues/#findComment-4207131
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
