  • Replies 225
Posted Images
Actually Doof I wouldn't mind to :rofl: if the invitation is there LOL.
Providing the car is running (it isn't currently) then I'm sure it wouldn't be a problem :)
Just have to sort out a small little matter of AN EPIC OIL LEAK!
grrr... I'm no mechanic that's for sure :)
I wouldn't mind putting the 31 on the rollers again.
Can we have a non-turbo and turbo RB30 class, cause for us N/a RB nutters we can get out run by a bloody comonwhore or something like that in the N/a class and we would get toasted in the RB30 class by someone with a turbed 30, just a suggestion.
I'll see if some of the guys from the R31 club would like to come along also.
Interesting... can we rock up on the day or do we have to make 'bookings'
You can just rock up, but the earlier you get there the earlier your car goes on the dyno - first come, first serve.
Ill try to have my new air flow meters on and a retune by then so I can aim for over 300kw, Im definitely in...
Will there be more GTR owners coming to this one then the JEM one? I feel I let the GTR guys down by being the only one there and only getting 254kW
i'm in but at jem they said i had some high end pinging and that thing sitting at the front of the rb25 engine had to be moved clockwise by a mm or something, the guy just loostend the bolts and tapped it around a few times with a spanner and said that should be it...... he didnt re dyno it to see if the pinging did go away....
if its not it and the guys at uas says there some pinging and that thing needs to be moved around again will they do it???? it only takes a minute to do but you need a dyno to know if the prob has been fixed..... i really dont care if they wanna charge me for another dyno run (id rather they didnt charge me for another run) aslong as the prob is fixed because at the moment i'm advised not to let the revs get past 7000rpm or risk damage to the head gaskets or something.....
also should have a fmic by then, mabey a boost controller
Me and Sean will be there we both have R32 GTRs mine was getting tuned at the same time as yours.
That's your crank angle sensor and it adjusts the timing. With too much timing your car can ping. Have you got 98 ron fuel in there?
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
