hi again guys,
yea last time i posted the problem on my r34 gtt that was boost cutting in 5k rpm.. now its cutting of 4.5k rpm and not reving past 5k rpm.. its like rev limited to that point.... any of you guys experienced anything like this before? need some assistance please. im starting to worry that its not my coils and plugs anymore...
anyone located in sydney?? st. george area
https://www.sau.com.au/forums/topic/240568-car-wont-rev-past-5k-rpm/
it wont be coil packs. you will feel them break down and you'll lose at least one cylinder. it wont limit revs as such, but will struggle to climb.
AFM could definately cause this. but then you would usually see some issue at idle, and cruising off boost too. although AFM symptoms can be pretty random.
Could be CAS. ie timing issues.
edit: Send me a PM if you want. I'm near Hurstville. If nothing else, I can spot if its a coil pack issue.
Edited by Munkyb0y
its frustrating i just got the car for almost 3 weeks now and its having problems already LOL!! xD. anywaiz there no idle issue and when im cruising on low boost its going fine it only happens when i hit 5k RPM on any gear
PM sent Tony. cheers
Edited by R34~neo6~turbo
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
