for about a month my oil pressure has been under 4 on the oil pressure gage. Previous to this it was always just above the 4. This is during normal driving. At idol it is almost hitting the bottom of the gage. I have checked the levels, and I only had the oil and filter changed two months ago (mobile 1 ). I have booked her in for a service this week, but after a recent bad and very expensive experience, I want opinions from you guys first, before the mechanic gives me his version.
https://www.sau.com.au/forums/topic/24058-low-oil-pressure/
my oil pressure dropped from what used to be half mark warmed up to 1/4 mark idle after changing to lighter castrol formula r 5-40w. i figure its just cause the oil is lighter so pressure is different. under load i think it goes up to the half mark. the old oil that was in it must have been thick as it never seemed to move even when it was on load. does this sound right?? can anyone shed some light??
https://www.sau.com.au/forums/topic/24058-low-oil-pressure/#findComment-515509
it will depend on the opil u use and the temp of the oil .
thinner oil lower pressure hot oil =lower pressure too. dont forget the oil doesnt get hot quick like the coolant it may take half hour driving to get to say 120 . u may have a crook oil sender or crook gauge . pressure is not tha important volume is as long as u have oil pressure it will be ok
https://www.sau.com.au/forums/topic/24058-low-oil-pressure/#findComment-516195
RB oil pressure sensors/senders/gauges = dodgy. Get a good aftermarket one if you are worried. I have a Greddy oil pressure gauge - when the car has been running a while the nissan gauges cracks the poos and wont really read higher than 2 or 3. It is simply not reading accurately. I've had no problems with the Greddy unit.
https://www.sau.com.au/forums/topic/24058-low-oil-pressure/#findComment-516416
its not just rb gauges that dont read accurate most stock gauges dont . dont forget most cars dont have any at all just a warning light that goes on when pressure drops to about 5 -7 psi .
the gauge is not there to tell u when u r low on oil it wont do that , driving easy it will pick up oil even if u have 1 - 2 lts in the sump . the dip stick wont show anything if it drops to 3 lts . between min and max on the dip stick its about .8 lt ( rb25det,1lt rb25de ). the gauge is there just in case ur oil pump stuffs up , if u r contantly looking at it u'll se it drop and may save ur engine , but u'll hear the bearings knock as soon as pressure drops if the sound system is not to high lol !!!in both cases the big end bearings will pick up a little ( the gauge reacts slowly ) but will be ok if u stop the engine quick . if u install a mechanical gauge ( most accurate ) they all use plastic tubes these days the plastic tube can come out when the oil gets very hot , u loose oil and bingo the end of ur engine .
if u r worried have the pressure checked and if u want install a aftermarket gauge but remember its only a guide and u dont need huge pressures as long as the volume is there u r fine .
standard rb 25det pressure is : idling ( 650 rpm )1 kg/cm2, 2000 rpm 3.5 and 6000 5.6 .thats when oil is hot , if u dont have a temp oil gauge after normal driving for about half an hour , and using normal spec oil , thinner oil =lower pr thicker oil =higher .
i dont know at what pressure the release valve will open but on my gtr it opens at about 6kg/cm2 , i think the rb25det opens a little higher .
the rb 26 pressure at 6000 is lower as well 4.6 and 3 at 2000 which goes to show u that u dont need high pressure, volume is more important .
https://www.sau.com.au/forums/topic/24058-low-oil-pressure/#findComment-516561
by the time u see the coolant gauge go up cause u got no oil pressure ur engine has probably spun all the big ends and the crank is ready for scrap . u will hear the big ends knock as soon as pressure drops . when ur big ends have a big clearence ( worn say 1-2 thousants ) when u first start the engine u'll hear the big end bearings a little for a few seconds another reason u dont rev the eng when u first start . when u do an oil change u may notice the same thing if u dont fill the oil filter with oil before u put on ( imposible in the skyline pos in some cars that the filter is upright .
https://www.sau.com.au/forums/topic/24058-low-oil-pressure/#findComment-516571
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
