i sanded my car in 240 which only now i found to be WRONG!!!!
but is it a big deal just means it needs to be primed first is this not correct?
i thought i knew stuff but....................................
nothings ever as easy as it seems. ;)
https://www.sau.com.au/forums/topic/240615-sanding-my-car/
lol you'd use something around the 1000 range and make sure its wet...
primer should hopefully fix it, might need a few coats... just remember that any blemish in the primer will looks 10000 times worse once the paint goes on...(paint doesnt cover it up like some people may think)
https://www.sau.com.au/forums/topic/240615-sanding-my-car/#findComment-4203000
listen up mate:)
if your car's in 240 theres two ways you can go about it...throw it in primer which will help in the appearance when its all finished or you can go out and throw some 320 then one 180 on an orbital sander and get all those 240 scratch marks out...only problem there is dont know how competent you are and how thick your paint is you might rub through and if its badly rubbed through might show up when you finish painting it.
https://www.sau.com.au/forums/topic/240615-sanding-my-car/#findComment-4203615
mate if i was you take it some one who knows what they are doing me and my dad are doing my GT-R and the only reason im letting him touch it was because he used to run Nissan Australia's production line for body work back in the day and is a panel beater by trade! and even with him working on my car not everything is going to go to plans but if you have some questions or need some advice ask me and ill ask him and will be glad to give you a hand
https://www.sau.com.au/forums/topic/240615-sanding-my-car/#findComment-4203885
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
