last week i changed the water pump in my r33gts-t s2 as it had a small leek at the top ,i used a second hand pump that was almost new- after putting it all back together and using a new genuine timming belt there was a dull whinning sound coming from it as it was warming up i was giving it slight revs to try and pin point the sound then the hole front off the pump ripped itself to peices and dropped the fan into the radiator wich caused enough damage to have to buy a new radiator. i thought it might have been the second hand pump so i got a brand new one and radiator and spent most of the week re installing it & finished it today and it was all sweet so drove it 50km to work with no probs but at midnight when i went to leave i gave it a rev in nutral to aroumd 3500rpm then it all shat itself like the week before --now my cars left at work 50+km from home with the water pump shatered again -so i need help what could i be doing so wrong --could i be overtightening the alternator/waterpump belt that might cause it to rotate of ballance then brake with a sudden rev or something else ?
this is the first pump it still spins so it hasnt seezed up the second new pump has brocken in the same way
Damn, never seen that happen before! That's not cool. When I've played with em I've never had that happen.
Now question time:
Genuine or non genuine nissan pump.
Did you torque bolts in accordance with the manual.
Did you check tension of belt in accordance with manual.
Are the mating surfaces true (flat).
This happened to me as well ! For me it was the water pump pulley was bent and was not running true ! It looked liked it was and took quite a while for me to find ! The previous onwer must of had an accident and bent the pulley but in stead of gettinig a new pulley they machined the inside of the pulley. What this does is makes the belt run true but transfers the wobble to the water pump shaft. The vibration then shatters the water pump. I replaced the pulley (VL holden 6 is the same pulley ) and that fixed it !
So I'd say something aint running true on yours as well.
Now question time:
Genuine or non genuine nissan pump. BOTH GENUINE
Did you torque bolts in accordance with the manual. NO
Did you check tension of belt in accordance with manual. NO
Are the mating surfaces true (flat). NOT SURE
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
