Item: Two x DD audio 3512e's Dual 2's. 1200RMS.
Item Condition: Brand New in original box.
Reason for selling: Cant afford to continue with audio and i think im losing my job tomorrow!
Price: $750 ONO each. RRP is 939.
Payment Method: Prefer pickup but will post at your expense, Payment will be made before postage!
Extra Info: Its heavy and you know you want it!
1200RMS Awesome quality sub brand new and dirt cheap. In dual 2 config so its great for the amps below as well.
Pictures: http://www.ddaudio.com.au/#/PRODUCTS/SUBWOOFERS/DD3500
Item: 2 x M2's 1700RMS @1Ohm Class D
Item Condition: Brand New in box
Price:900 ONO each. 1099 RRP.
Extra Info:Its heavy and you know you want it! Awesome amp for the above subs or any other for that matter. Superior build quality. Just buy it!
Pictures: http://www.ddaudio.com.au/#/PRODUCTS/AMPLIFIERS/DDM
Item: 1 x C4a 4x100 or 2x350RMS
Price: $475. RRP is $549. Will only sell if one amp and sub go.
Pictures:http://www.ddaudio.com.au/#/PRODUCTS/AMPLIFIERS/DDC
Im happy to take actual pictures for anybody who has a genuine interest but they are packaged up in boxes as new so prefer to keep them that way. Happy to post. Any Q's just ask.
https://www.sau.com.au/forums/topic/240653-brand-new-dd-audio-gear-cheap/
Now listed on ebay. Starting bids of 650 for the amp and 500 for the sub! That’s like half the retail value! Go grab a bargain.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=300268045955
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=300268047931
  • 3 months later...
  • 4 weeks later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
