Here is the page of the powerfc d-jetro that explain how to connect boost control kit but it is in Japanish.
http://img408.imageshack.us/my.php?image=b...ntrollerrz7.jpg
I would like to use the map sensor and solenoid valve from my avc-r as I read that can work fine because they are the same as power fc boost control kit
So I have 3 wires from map sensor Signal, Ground and +voltage
and 2 wires from solenoid 12V and ground
As I can undestand from my excelent Japanish that I know :D
1. Put off the 3 pins from the boost control plug, the central is map signal.
2. Put the map signal in the central plug from d-jetro sensors.
3. Put the other two pins at voltage and ground on the d-jetro plug.
Ok with the signal wire.. ok with the voltage and ground from the map sensor..
But solenoid voltage and ground from the same wires with the map sensors?!?!
So how will open and close the valve?!?
How it will work?!?
Map sensors needs always voltage so how will control the valve?
I would like to know because I am afraid to don't do any damage!!
Ok if you give me one for free :/
Sorry mate but I ask if I can connect the solenoid and the map sensor and if I understand what and how to connect.
I don't ask if it is good power fc boost controller or an independant one :(
I have an avc-r but I don't want so many screens in my car :S :S
Edited by GreeceS13
I wish i had $1 for everytime ive seen someone send you to visit Pauls power fc FAQ.
Because every question you have asked to date is in there or in some other thread on SAU.
So for the effort of my post, you OWE ME $1. I will PM you my paypal details.
GO READ THE POWER FC FAQ!!!!!!!!!
Ofcourse I have read it.
Many many times.
It hasn't everything...
Anyway I think that in my first post I have understood wrong how to connect the solenoid and the map sensor.
Map sensor... 3 wires... 12V, Ground and signal... we connect them at the plug near the commander. Left 12V, center signal, right ground.
And the solenoid I must connect it at the stock loom?
I didn't know that rb26 have from stock solenoid valve.
So solenoid has 2 wires... Voltage, ground.
Voltage to the ECU pin 25 "Wastegate valve control solenoid valve"
and ground from everywhere?
PLEASE ANYONE WHO KNOWS CONFIRM ME PLEASE THEESE
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
