Wednesday around 8:30am, cruised behind a midnight purple 33, gold 19s, from Swansea to Bennetts Green.
Stuck to the limit like glue, while everyone else was rushing to work. Not that thats a bad thing, just seemed paranoid.
Gave a flash as I turned off.
i saw you go past my work jason man, saw you heading to wyoming at 4pm
awwwww! i always look but neva see u :O... i spotted urs in the street tho :banana:
spotted a black 32 gtst, plates "EMU14V" near the punt bridge a few days ago... also a silver R34 4 door near fountain plaza the same day
Haven't been on here for ages so I didn't know this thread existed - but yes I own the "other black R34 GTR vspec" in newy - with the Silver LMGT4's :O
Saw a blue R34 GTR heading towards Koorangang yesterday arvo on the way home from work. I was in my mate's 31 at the time so he prob wouldn't have noticed me :banana:
i own the blue v spec 2 was going to the airport back to work i live in perth but keep the car there in newy but its now in perth
spotted a few lines last night in my new hood hahaha
go the coast!
Spotted some random last night in a red NA6 Mazda MX5 with black wheels - his face looked familiar from Coastie meets way-back-when!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
