Spotted a white Stag at The Entrance earlier today, plates were DA something something
That would have been Alex (CL11QE).
Stagea spottings over here: http://www.skylinesaustralia.com/forums/topic/53437-spot-the-stagea/
Spotted a purple? r33 at kincumber shell tonight and i think at green point almost getting done by the cops with me (White turbo r31 silouette), I turned off near bi lo with him to to avoid the cops gettin us for havin a little run hahaha
who was the tosser in a black r33 at 7:15-7:20pm last night leaving Kaiong Shell with red number plates doing a burnout across the intersection?
f**king tosser - GTFO
(was with a black supra, white 33, and a civic - these seemed to have a good attitude)
Felt like a busy day for skylines today?
- Parked next to a silver R34 4-door and white R33 (gts?) in the staff parking of Westfield Kotara this morning
- Spotted an insane looking black R32 (gtr?) between Cardiff/Charlestown this arvo
- Spotted/got a wave from a white R34 (gtt?) also in Cardiff a few minutes later
lol sounds like jason! lol
  • Like 1
could't have been Jason...he was in church with me and then we used his car to deliver clothes and food to the homeless in a remote country town far far away but not before we were saving baby dolphins at water world.....
so no, couldn't have been Jason.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
