[quote name='SNOQPY'
did think it was a GTR but its always parked on vales road aka the main road, but maybe im thinking about another 32. lol
ALSO
spotted miss33r in long jetty parked outside mitre10 i think it was and a few other 33s around the area.
Cool you spotted my girls car miss33r ....
yeah i know man , they are glazed and i dont know how to fix them , ive sanded the shit out and it fixed them for about about 30min and them its back to what they are doing now
You are not bedding them in properly then. They worked for 30mins because sanding removed the glaze, but they just glaze over again as you dont bed them in properly. Look it up on google.
Basically you want to drive around at about 40km hr and keep applying your brakes and releasing, the idea is to not heat them up much at all, while wearing them in to the shape of the disc. So about 10-20 light applications of the brakes, no heavy stopping or anything.
Edited by Smegul
Returned a wave from a black r33 on lake road heading toards wallsend about 10 or 11am on saturday morning.
Gave a wave to a blue r33 gtr on university drive about the same time, but don't think he saw me.
Thanks for that man , i will give that a go
I keep seeing a silver 32 on maitland rd it has gay clear led taillights! Neighbor across the road has a white 33 and always see a resprayd blue 33 around mayfield!
Some of my mates cars aroumd newy. White 180sx with black roof and black bonnet BFJ.70H swansea, r32 4 door gunmetal grey white or purple rims , my R32 gtst resprayed blue EVL.32R plates mayfield . Mates burgandy auto 300zx tt maitland , black 32 gtst work rims sunroof swansea, blueish r33 morpeh also has a turbo eb xr6 white with black typhoon rims, red turbo tx3 laser black bonnet evo vents massive fmic, white vp ss serious 5 ltr looks stock. Have more mates with imports etc but there the main ones you will see around im sure they will wave back!
Also if you see a red R35 gtr thats my mates you might see him in newy or greenhills/ maitland older guy comes from gresford near dungog he full on owns a farm and drives it like a 4wd i seen all hay in it one day and was like wtf have you been doing and he was like well it is awd lol nice car tho besides he full on touches all the interior with greasy kfc fingers lol
Edited by jahn-15
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
    • You're selling the SS?! How much are you asking on it?
    • My answer would be, that depends. If it's something that can be grumpy to start, runs a bit rich, and is likely an expensive engine, then yes, I would. But there's a few reasons why. Sumps aren't really sealed, there is airways to them, so it is technically open to moisture. Secondly, if as mentioned it has been started, and it's a fuelled up, I'd dump it, as chances are, fuel is in the oil. Next to that comes, how much use had said oil seen before it was parked up. IE, how much carbon, and potentially fuel/water did get in there while it was being used, and has now been allowed to sit, and slowly come together? For the most part, if it's just been something like a road car, stock engine, nothing wild, f**king send it if it's not near oil change spec.
    • I forgot to say Mark, you know how if you lack sleep, we get Grumpy Mark? When I lack sleep I'm Grumpy Matt. We must be the GrumpMa's!
