  • 5 weeks later...
Seen a red R35 GTR twice now, I cant remember the plates but they were custom and for memory were a name, possibly asian name. First time I saw it in Jesmond the second near Sandgate. Other then that, literally seen no skylines at all except some civilian r31's since I moved here in February..
Edit: Just remembered I have also seen a blue R34 GTR parked on University Drive a couple times too near the Stannett Street lights.
Edited by Bennis
yes is asian I saw it in City Mcdonald.
Must be skyline day today
Spotted a maroon 33 while turning into a car park at Cardiff then when I spotted a car space it was a silver 34 backing out while I waited to drive in
Then at Kotara a white 34 sitting behind me at the lights and then when I parked I spotted a dark grey 32
All cars had a very nice note as well
Hey boys (and girls) umm i planned on changing my exhaust manifold gasket on my car and low and behold i found that 6 F!@King studs were snapped in the block ( i didnt do it btw). Was wondering if there is anyone in Newwy that does stud extraction?? Cheers in advance..
Been seeing a nice DR30 two tone: grey over black skyline sedan.
Also a R31 skyline passage pillarless with the plum velour trim.
Both very nice. Also seen a few V35s and M35s nice to see some VQ lovin in this otherwise RB dominated city.
  • 4 weeks later...
Helped my brother move to the Marmong Point area yesterday. Neighbour behind him had a whole gang of Skylines and other imports he was working on. If you're on here I love your yard!
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
