Got word that there is going to be a fair bit of defecting going on in Newcastle the next 2 weeks... Lot's of undercovers getting around ala Operation Typhoon.
Ohk i can 100% confirm that what Finchy said is correct, Got pulled over today on Glebe rd, There were about 5-6 cop cars spread out over 100meters.
He told me they are pulling over anyone with a loud or done up car, Seeing if they have Un-boxed pod's etc and will be given notification in the mail withing 4-6 weeks to go see the redhead decc station to take your car over the pits.
So be careful for next few weeks.
Cheers James
Cheers James
So were they fully harsh? did you get pinned for any thing?......
Whats the go with the notification did he tell you that you would get one?
Nah he was heaps nice to me and all surprisingly, asked me if i had a any questions etc.
He said a letter will get sent out withing 4-6 weeks regarding me to go get my car checked at redhead.
If it passes exhaust db and no illegal mods etc you "HAVE" to pay $70 no matter what for them to go over it, and thats your own expense even if nothing was illegal.
illegal you get defected and have to fix it thats it
Spotted R34 coupe at Supercheap Auto Kotara today, plates were NEO666 I THINK, or something-666 anyway. Had a massive wing on it, and R34 GTR rims.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
