hey guys
just picked up my first 32 yesterday
and i dont really like spoilers as i have taken it off my s13 prior
ive taken the three screw things off underneath the boot already where the spoiler seems to be bolted on to
but its still stuck...
any tips??
thanks :D
https://www.sau.com.au/forums/topic/240687-how-to-remove-r32-gts-t-spoiler/
hey guys
any tips??
thanks :D
They are double sided taped on...get some fishing wire and slide it around to cut through the tape then carefully removal the spoiler without ripping up any paint...remove the tape from your bootlid and have fun blocking up the holes:)
lol thx guys.
ill get some fishing wire.
havin another crack now.
and good old electrical type will save the holes once again :D
just make sure while your doing it i prob shoula told you this before...make sure the edge of the tape your cutting is closest to the spoiler...e.g pull up just so you dont burn or scratch the paint that will be on the boot lid
yeh i failed
its on there pretty darn well
do u need to use some force in ripping it off?
and the fishing line was killing my hands.
maybe i should just leave it on for now
prob just lower my car first then
get the spoiler thing fixed afterwards.
hey guys
i still cant mange to take my spoiler off
ive used fishing wire to cut underneath the double sided tape on the side between the wing and the tape. not the tape and the boot
how exactly do u guys mean cut with fishinwire? im just moving it back and forth and it get sstuck sometimes and it hurts my hands
and where does the bolt pole that goes thru the boot is located on the spoiler
im a bit retarded sorry
can someone please teach me to do it from scratch??
thx
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
