Make:Nissan Skyline GTS-T
Model:1995
Milage:111,000
Transmission:Manual
Colour:White
Currently registered?YES
Price:$16,000 Negotiable
Contact:0423472320
Comments / Modifications:
ENGINE:
Engineer Certificate ready,Trust/Greddy TD06-25G Turbo(same as T67), Apexi power FC Computer
with hand controller, Trust 40mm wastegate, Tomei 256 poncam, nismo 555ccc injector, hybrid moster
intercooler, Nismo Strut brace, Plazmaman plenum, Blitz Turbo timer, HKS highflow pod filter, blitz
electronic dual solonoid boost controller, Heavy duty clutch.
Car being Dyno and tune making 270KW (360HP) could get more power out of it if tune again.
EXTERIOR:
Low Suspension, Carbon fibre bonnet, 19 inch Starcorp rims 90% tread, DBA slotted rotor front & back,
Trust Front bar, Wide front Fender with fin, wide dual blade spoiler.
INTERIOR:
Very good condition Front and back seat no hole, must see, driver and passenger Bucker seat, gizmo
shiftlight, Boost gauge, Apexi Hand controller, Turbo timer.
I still got standard part for this car, all can go with car. rims tyre, spoiler, front bar, exhaust and many
more
Picture are at this link:
http://www.carsales.com.au/used-cars/priva...mode%20matchany
Contact:San
0423472320
https://www.sau.com.au/forums/topic/240710-nissan-skyline-gts-t-95-350hp/
