Ok guys need some input here.
I'm in the process of ordering parts for a rebuild and so far i've sourced CP 20thou 8.5:1 pistons and an ACL main/rod bearing kit.
The problem is with the head gasket--- I'm only getting 87mm cometic gasket. Will this work with the 86.5mm bore?
An should i wait till the machinist deck/shave the block and the head then determine what thickness hg to use?
I want to maintain a CR of 9:1 or for the least 8.8:1
I guess decking/shaving and using a thinner HG would be the only way to bring compression back up since i cant seem to find 9:1 oversized CP pistons.
https://www.sau.com.au/forums/topic/240776-head-gasket-bore-thickness/
yep, pretty sure .5mm over is the way to go for a head gasket
but im no engine builder, im sure someone with more experience will correct me if im wrong
CC ur head, then work out the CR with a 1mm gasket, then a 1.1mm so on and so forth, then you can work out which gasket you want to use, and/or how much the head needs to be shaved
