i lost my t/spool sound the other week,while playing with my vacuum lines,i swapped some around and found what ever i did it made my bov sound louder,but lost my spool sound,after changing over,it came back,so i found out that a change in the pressure can do wonders. Didnt notice change in power,turb still spooled over, not sure what damage etc in long run could have done,but it works how its supposed to so thats all im worried bout now
the only way a vaccum line can alter the spool sound is if it is making the wastegate stay open instead of closing (so exhaust air isn't making the turbo spool), and if that was the case you wouldn't have boost.
i'm guessing your spooling noise possibly isn't actually your spooling noise but a leak (such as bov not closing 100%) especially if what you did made the bov louder (you probably made the bov close properly).
what pod filter are you using?
  • 2 months later...
hi mate thnks for the reply
its got no pod filter
one more question thing they say its a faulty turbo so is it ok if keep driving the r32 ? or is there any option to remove the turbo and drive it without the turbo like non turbo or fit a new non turbo engine in the car
Hey mate don't listen to all the people putting you down.
Just take your working/stuffed turbo off and fit one of these suckers!!
1. Improved fuel economy
2. Instant increase in engine power?
3. Reduction in carbon accumulation to your engine
4.Minimized air pollution
5.Enhanced throttle response and acceleration
6.Easy to install,DIY.
Super Spiral Turbo Ventilator creates a vortex air flow to imporve air & fuel mixture? enhancing your engine's performance.It reduces the carbon accumulation in the engine and substantially increases the horsepower to your engine.
Super Spiral Turbo Ventilator blades are made of advanced precision bearing technology (running up to 30,000RPM). Yep The blades are made out of bearing technology!!
Aluminum alloy gravity diecasting design is not only anti-rust, but also has the ability to match your high-revving engine. The blades have special angles to promote extra air flow to the inlet manifold and assist in providing better engine combustion. Experience strong torque during low to medium RPM ranges but also extreme horsepower at higher engine revolutions.
Furthermore, it is environment friendly and greatly increases performance efficiency.
The products can be installed to gasoline & diesel cars, as long as there is
the inlet pipe on the air inlet of the throttle.
HAHAHAHAHA!!!!!!!!!
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
