I'm guessing you actually want to know the size, despite not asking that. They are 8"
Thanks mate, yes that's all I was after, I knew they 18" diameter, just wanted the width.
Cheers
Paul
  • 3 weeks later...
  • 8 months later...
Tried to message you chris dirrectly but the forum would not let me, im in perth and the radio has lost power and the aircons stuck on, can you fix it? Or know anyone over here who can
Edited by 180sxslider
  • 4 months later...
Call any stereo shop in the Sydney area. The can help you with speaker plates.
0295455577 is one that I use. Speak to Owen.
Edited by Chris Rogers
  • 2 months later...
Hi Guys,
Where can i get a Bose Interface & Storage pocket, im looking to do a double din radio swap as I'm sick of the factory CD player skipping all the time.
I currently have the Bose system with navi and reverse camera. I still want to be able to use the reverse camera.
Cheers.
CAN I REPLACE THE RADIO IN MY CAR IF I HAVE THE BOSE PREMIUM AUDIO
yes it is possible.
you need:
new 2DIN facia panel to suit your car.
new A/C controller (two versions with 'DUAL' button and without)
Bose interface (there are two versions with NAVI and without.)
Rear Bracket
Nissan Storage Pocket
note if you do not have BOSE audio the process is a LOT easier. you do not need the bose interface.
Contact me and I will help you.
Hi Guys,
Cheers.
CAN I REPLACE THE RADIO IN MY CAR IF I HAVE THE BOSE PREMIUM AUDIO yes it is possible. you need:new 2DIN facia panel to suit your car.new A/C controller (two versions with 'DUAL' button and without)Bose interface (there are two versions with NAVI and without.) Rear BracketNissan Storage Pocketnote if you do not have BOSE audio the process is a LOT easier. you do not need the bose interface.
  • 7 months later...
On 20/10/2008 at 6:27 PM, Chris Rogers said:
AUDIO/NAVIGATION RELATED QUESTIONS
MY CD PLAYER ATE MY CDs AND WONT GIVE THEM BACK
if the 6cd indash unit displays ERROR F0
CD mechanism is jammed due to a nylon guide that has splintered in the transport. the discs cannot be removed without literally stripping the whole thing down.
the unit can be repaired for $550-650 depending on the overall condition of the CD unit. parts are Ex Japan
MY CD PLAYER SKIPS OR WONT PLAY NORMAL CDS - I SEE 'ERROR F3' ON MY SCREEN
time for a new laser. repairable at a cost. WORST part is the labor to remove and refit it. laser is available locally. this IS NOT a DIY job
DOES THE FACTORY CD UNIT PLAY BURNT CD'S / MP3 format
- yes it does. it DOES NOT play CDRW. it does not play mp3 discs
CAN I CONNECT AN IPOD TO THE FACTORY RADIO
yes and the radio WILL control it OR if you have the factory NAV screen it can be done as well.
there are two methods
Method 1
the other one will use the factory radio as a controller and you can drive the IPOD off the steering controls IF you have them.
yes it is possible.
you need:
Rear Bracket
CAN I ADD AN EXTERNAL AMPLIFIER(s) TO THE EXISTING RADIO
without bose audio - yes you can. the process is the same as a 'normal' radio.
with BOSE - again yes but you will need an interface.
I WANT TO CHANGE MY SPEAKERS - WHAT SIZE ARE THEY??
front are 6.5" tweeter is a 1" soft dome
front speakers require a mounting plate to be made for proper fit.
rears are 5.25" and require TOTAL removal of the rear area for access.
if you have BOSE audio the 'subwoofers' are 6x9s. amplifier is located in the boot rear left on floor under panel in coupe and under rear shelf in sedan.
I HAVE FACTORY FITTED NAVIGATION WITH TV. HOW CAN I:
1. GET A MAP DVD SO IT WORKS IN AUSTRALIA
2. CHANGE THE TEXT TO ENGLISH.
3. CHANGE THE TV SO IT WORKS HERE.
1. No. There are no maps for this unit used in the Australian market. It can be converted using a local unit if Navigation is required
2. there is a software hack in the works from russia that will reportedly fix this. see HERE for this. this DOES NOT FIX THE MAP ISSUE!!
3. Japan use an ENTIRELY different televison system that cannot be converted for operation here. a local tuner must be fitted for TV to work. it is suggested that the antenna system be changed as well for one with higher gain and better reception.
Hi Chris. I have 2001 v35 350gt sedan. The stereo broken. I bought a second hand to put in. It works great with Aircon but stereo like Dics and Radio not work. It couldn't find any FM or AM channel. It show CD error F3 on screen. I am grateful if you could give some advice.
Danny
  • 2 years later...
I use a nissan v35 with vq25 engine. He was spending a lot of fuel and had to replace the engine with a new one of Vietnamese origin. The new engine did not come with a computer so I had to use the old installation. At this point the engine does not start because. Does anyone help me there?
  • 3 months later...
Hey did you ever end up finding out what the problem is I’m having the same issue right now
  • 9 months later...
5 hours ago, 370 GTS said:
its automatic. you might have your Speed sensor wire cut.
Some of the Vs have an aftermarket switch to turn the sensor on or off so they can use the TV, DVD or Aftermarket Sat Nav while driving.
I Did on my V35 and do on my V36
Edited by V35_Paul
Thanks Paul, there is a couple of switchs that I have not worked out what they do.
  • 5 months later...
me too did you ever find a resolution or is it a new interface?  my tv screen nor any of the buttons work and the aircon stuck on auto
its a design fault within the unit. takes out the main panel. the TV/ navi is a different system . so you have two problems. the first of no AC is easier to sort by replacing that assembly and putting a new radio in. the non functional screen is a problem with the navi unit above tyhe glove box
  • 2 months later...
  • 5 weeks later...
On 24/12/2008 at 1:02 PM, Chris Rogers said:
MODIFICATIONS
Cruise Control
these cars DID NOT have Cruise control factory (exception is the USDM G35.) . you can fit a Vacuum unit or DBW Setup to them without hassle. I do a fully integrated DBW setup for these that runs the original Controls on the steering wheel ( you MUST have the standard wheel!)- Contact me directly if you want one done. if the car is going through compliance here in Brisbane it can be done there also.
radio controls on the OE steering wheel.
this one is a 20 minute mod that is literally a plug in and work affair. parts are available from me/ nissan Oz for this mod It involves removing the steering wheel , removing the blank on the left side, putting the factory piece in place, putting it back together and enjoying. makes driving your Ipod a LOT easier that fiddling with the radio
Hello Chris, how do I get in touch with you for this cruise control mod.
I have just bought a 2008 370 GT and was about to go ahead with an aftermarket unit but you sound as if you can give me something genuine. Anyway, I wait to hear from you.
Cheers John
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
