Recently ive been asked about correctly degreeing camshafts in RB engines, this step by step guide will hopefully answer a few questions and allow others to understand how its done and use this method to set up vernier cam gears to find exact lobe centers.
Cam gears help you to adjust your cams so that it opens and closes at the correct time. It also insures that maximum lift correspond to a desired crank position. The center line or the point on the cam where maximum lift occurs is known as lobe center.
Setting the cams to zero on the cam gear means absolutely nothing as different manufacturers of cams and cam belts can cause exact position of lobe centres to be slightly incorrect.
Lobe centers on the HKS 264's are 110 for the inlet cam and 103 for the exhaust cam. Adjusting your cams too these specs will most probably bring them very close to their maximum designed performance . A lobe center of 110 on the inlet cam means that maximum valve opening will be at 110º ATDC and 103 on the exhaust will mean that maximum valve lift will be at 103º BTDC.
This is how I degree my cams
1. Use a pencil, paper and arithmetic for this procedure, to keep track of the results.
2. Make a rigid pointer from stiff wire or an old coat hanger and attach it to the engine block. This pointer locates the degrees on the degree wheel.
3. With a degree wheel installed on the crankshaft, rotate the crank to get the no 1- piston at TDC and check to ensure that the valves are fully closed then adjust the pointer to zero (0º TDC) on the degree wheel.
4. Turn the crankshaft opposite the running rotation approximately 15-20 degrees. Install a dial indicator above the spark plug hole (i use a flat metal plate ive fabricated that bolts to the coil pack bracket holes) with the rod of the gauge going down the spark plug hole to check the position of number 1 piston.
5. Continue to turn the engine in the same direction until the piston comes back up and just touches the dial indicator. Make a note of the exact number on the degree wheel that the pointer is on.
6. Rotate the engine in the other direction (running rotation) until the piston comes back up and touches the dial indicator. Again note the number where the pointer is.
7. Remove the dial indicator and rotate the crankshaft to the midpoint of the two marks. At this point the piston is at the true top dead center. Loosen the degree wheel and adjust it so it will read 0º TDC at the pointer. Don't rotate the crankshaft to do this!
8. Now, it's time to locate the lobe centerline relative to TDC. Attach the dial indicator on the top of the head. Set the tip to contact the top of the no 1-cylinder inlet valve shim/bucket. Check to make sure that the indicator plunger is parallel to the valve stem. NOTE - any variance in an angle will produce geometric errors in the lift readings.
9. Rotate the engine in the normal direction of rotation until a reading on the dial gauge of 0.040 lift is reached. (Valve will start to open) Mark the dial gauge and make a note of the reading on the degree wheel.
10. Continue to turn the engine in the normal direction past maximum lift. The valve will now return to its close position. Make a note of the degree wheel reading when the indicator reads 0.040" on the return side
11. Now add the larger of the two readings that you noted on the degree wheel to 180 subtract the smaller number and then divide the answer by two. Your answer will indicate the lobe center of the cam. Example: open reading was 4 and close reading was 43. Now add 43 to 180 = 223, subtract 4 =219 divide by 2 = 109.5. Lobe center is 109.5 degrees.
12. Continue to move the cam on the adjustable cam gear and redo steps 10 to 12 until the required lobe center is achieved.
13. Now do the same for the exhaust cam
Hope this is not too complicated to follow.
cheers
Paul
https://www.sau.com.au/forums/topic/240804-degreeing-camshafts/
  • 1 year later...
Hi Paul,
In my situation I am running a RB30 with RB25 Neo head, but I don't trust the timing markings on my car for a variety of reasons.
going from what you have mentioned above and the specs for standard RB25DET NEO Camshaft duration 236°in, 232°ex lift: 8.4mm in, 8.7mm ex
does any 1 know what degree's in relation to TDC the intake cam is set to standard @ 0.040" of lift? or what degree's the intake cam is set to at maximum lift in standard form.
regards
  • 3 years later...
Im running a 30/26 my exhaust cam card says at .050 should be 242 deg and intake is 253 deg at .050. does this mean in stead of
(9. Rotate the engine in the normal direction of rotation until a reading on the dial gauge of 0.040” lift is reached. (Valve will start to open) Mark the dial gauge and make a note of the reading on the degree wheel.)
I should be reading .050 and not .040
No, the mark on the dial gauge is just a reference. Really you can use any number you like, so long as you use the same number for all your measurements. So say you choose 0.040" then you just rotate the engine forward until the gauge reads 0.040" again.
Should also note that for RB's you need to preload the dial indicator due to the lifter design in a cam on bucket setup.
Yes, the 0.050" on the cam card and its documented lift refer to the lift you should see at a specific crank angle.
Between these two points is the crankshaft position where maximum lift occurs, which is also where the advertised duration measurement should be.
Just want to correct myself here and apologise if I mislead anyone. I re-read Paul's write up and realised he was using a different method to the one I used. My bad.
So in this case, YES set the dial gauge for the valve lift indicated on the cam card.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
