after owning the gtr for a few months now its time for..you guessed it. clutch upgrade.
im after something that will hold between 300-350rwk and is very practical/smooth.
i have been looking into the cushioned button exedy for the moment cause i want something that drives like semi stock and will handle some hard launches.
what are my options?
thanks
Anth.
  • Replies 49
One word....Jim Berry...but not for a 32..only for the 33 and 34...32 is in a much smaller housing.
The others are to heavy..this is a rebuild of the stock clutch...do not sell your old one.
The pressure is increased with less tolerances and better materials....
this allows for a higher clamp force.
There is a sticky here somewhere...could be in the drivetrain section on clutches
I think you'll find this ignites the "jim berry vs jap multi plate" debate
My vote would be nismo twin plate. It does the job perfectly, feels like standard, will take high rpm launches all day if thats your thing and your mum could drive it to the shops.
Or an OSGiken R3C if you dont mind it being a bit grabby
Nismo Super Copper Mix (Twin plate)
Drives and feels almost like a standard clutch and has no problem holding on to the power and torque of my 325rwkw, Rb30det set-up
I have never heard anyone complain about them and i know a few people that use them.
Nismo twin plate coppermix. I have the competition model which is rated a little higher with the Nismo Slave cylinder. I will NEVER change it for something else. It's behind a 400 rwkw 2.8 litre. Cant recommend it highly enough.
where can i get in contact with this jim? (jim berry clutch)
I would personally go a twin plate for that power. Have a read about some of the JB clutches. http://www.skylinesaustralia.com/forums/Cl...on-t233996.html
GTR32..smaller housing.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
