My main engine mod is the bigger exhaust (from front pipe to rear including gutted cat) and a bigger (Trust) smic and so far this is giving me 155AWKW. I have fitted the Jaycar boost controller and am now fitting the SAFC and SITC and will then tune it - but I'm not expecting more than about 160- 170AWKW until I get a new turbo to push it over 200AWKW. I have actually spent just as much money on the brakes and twice as much on the suspension and now i have a pretty zippy touring car but my first track day revealed
1. I need better wheels and tyres
2. My greddy speed cut thingy doesn't work so i still don't know how fast my car can go past 180km/hr
but more significantly...
3. Its slow off the line. Using just a stopwatch and the speedo my 80 to 120 time (done all in 2nd gear) is about 5.5 seconds which is comparable to the Holden Sportwagon Calais which also weighs 1850kg but is supposed to do 0 to 100 in 7.95 seconds (say 8) whereas even with booting the auto against the brakes I can't get much better than 11 seconds. Do other people with similar power levels get similar 0-100 times or is mine exceptionally slow? The 80 - 120 time is compatible with my current power level but I expected it to be a bit quicker off the line. A lot of fairly ordinary family cars can do better than 10 seconds. Has anyone else timed their car over 0-100 or 80 - 120? I am wondering if my Atessa is playing up. I'll change the ATF in it and give it a good bleed and see how I go after a tune.
https://www.sau.com.au/forums/topic/240865-how-fast-is-your-stagea-really/
My car pulls low 14's on the strip with 186RWKW (lighter, more power than 4wd) so should be in the 6 second range.
I have seen stock RS4 S1 stageas pull 16&17s down the strip which i would guess is near the 9-10 second mark for 0-100.
When you get it tuned get it up to 12 or so PSI. The SAFC in mine is running about -15% at 4500-6500rpm.
Where are you getting it tuned?
Edited by GorGasm
My previous stagea (series 2) had a larger turbo but still was only at 160awkw (9psi) and i had timed it 0-100 with a stopwatch (i know, not the most accurate way) and it was around 7-8 seconds. Sorry I couldn't be more specific but that should give you a rough idea.
When it had the stock turbo, the top end wasn't very strong. It was able to get up and going fairly quickly but kind of ran out of puff after about 4000rpm. After I upgraded the turbo, it was almost the opposite. More laggy, but once the turbo kicked in around 2600rpm it pulled pretty good. It would hit max boost around 3700rpm and would go strong all the way to redline.
Now I have an M35, and its a lot quicker than my series 2 (when it was stock). I'd say the M35 is quicker 0-100 than my series 2 was even with 160awkw, mainly due to the faster turbo spool and more torque.
anything over 8 seconds does sound a bit slow for a stagea (although i'm not sure of the series 1's).
my particular Stagea did low 15sec pass 3yrs ago (previous owner in qld) with just catback, pod and boost-T
done a lot of work since then, unlimited speedo even lol
should be 5.9 for 100m or there abouts, and 13.7-14.0 for 400m give or take
edit: plus Ive just collected all the Head work stuff (tomei poncams & lifters, 90mm throttle body, head internals), so should be good in half a yrs time
Mine does 11.9 down the qtr. Would be a heap quicker in some cool weather, it was 30 odd degrees that night.
Hey Ken, how power you got?
How quick is a 800-900hp V8 stagea going to be?
Time will tell :P
Just a pissy 500rwhp.
800-900 is mental, as are you, nice match really.
Not my car unfortunitly, but another forum members car. I do not want to steal too much of his glory
It will be a turbocharged nissan V8, so it should have plenty of torque.
Ps. I am only half mental. The full metal people are in Darwin :D
The sparky at Torque Performance is wiring in my SAFC, SITC and LM2 afr meter (yes I would say it is typically RB rich at max revs as people report flames shooting out of the exhaust on the track day) so once I sort out some form of knock detection I plan to tune it myself. I expect to be able to put some more advance in low down - it goes like a rocket from about 5000 to 7000 but want a bit more zip in the midrange. When I get a better turbo and my adjustable exhaust cam gear fitted I will tune it as best I can and then take it somewhere (Soichi?) and see how much they can improve on my tune.
[later] Just got my car back - it appears to be running lean in the midrange - will see if I can remedy that with my SAFC or whether I need to turn up the fuel pressure.
according to blaZT cable and laptop mine does 0-100 in 6.35 . on a luke warm evening with my fat arse and 1/3 / 1/2 half a tank of gas . de cat cat back HDI fmic and RB20det wastegate actuator
mines not running very good at all atm, installed a cheapo boost controller on the weekend ( not turbo tech, got one of those on the way now tho) and in 1st and 2nd gears it jumps nearly up to 14psi at about 3-4000 revs then drops back to normal boost heading up to 5 -6000revs once you hit third tho it only gets up to 7psi and continues to bleed boost as the revs increase.......this is all on the lowest boost aswell
so yeah, they are cheap version of the turbosmart in-cabin boost controller, and yeh i dont know whether i just got a dodgy one or somethin but yeah i wouldnt recommend them..
use you'r imagenation :P
A C-130 was lumbering along when a cocky F-16 flashed by.. The jet jockey decided to show off.
The fighter jock told the C-130 pilot, 'watch this!' and promptly went into a barrel roll followed by a steep climb. He then finished with a sonic boom as he broke the sound barrier. The F-16 pilot asked the C-130 pilot what he thought of that?
The C-130 pilot said, 'That was impressive, but watch this!'
The C-130 droned along for about 5 minutes and then the C-130 pilot came back on and said: 'What did you think of that?'
Puzzled, the F-16 pilot asked, 'What the hell did you do?'
The C-130 pilot chuckled. 'I stood up, stretched my legs, walked to the back, went to the bathroom,then got a cup of coffee and a cinnamon bun.'
When you are young & foolish - speed & flash may seem a good thing !!!
When you get older & smarter - comfort & dull is not such a bad thing !!!
Us old buggers understand this one!
hehe if you want your stagea to feel faster, drive an old falcodore for a couple of months... :laugh:
I've got an old R30 and an old Patrol.
I had a new EA once, what a heepa. And it was a Fairmont Ghia.
I had a new EA once, what a heepa. And it was a Fairmont Ghia.!
HTF do I get rid of this duplication????
Edited by 66yostagea
I can say stock S2 does 0-100 in 7.03; repeated 3 times with the same results. I have gotten a ~7.8 with 3 people in it; completely stock, stall launch.
PS just had it dynoed at 130.9 RWKW (next time it's going on a 4WD dyno...)
Edited by DaveB
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
