what are you trying to do eaxctly?
if you are looking to put straight video in there is a easier way. otherwise it will be RGBs and you will need a scope to find what you are after. do you know what video and sync signals looks like?
https://www.sau.com.au/forums/topic/240888-r34-in-dash-lcd/#findComment-4214849
I want to swap the the pop up lcd for a GTR MFD i have bought.
I have bought the sub harness from nissan that goes from the MFD to the connectors behing the guage cluster the old pop up screen has two connectors and the new one has three and they are not the same. so i have male and female connectors form the old harness and want to use them
Basically i wanted the pinout of the connectors behind the guage cluster so i could pull out each pin from the (pop up lcd sub harness) connectors and put the connectors on the MFD sub harness.
The (pop up lcd sub harness) has about 24 wires and 4 free spots for wires, and the MFD harness has 48 wires. I have another connector from a Honda harness i can use for the rest of the wires.
Know the stock Navi unit is useless here but i wanted to connect all the wires for it so that later when i replace it i can use the MFD as the screen for the new navi unit.
I have a scope and the R34 GTR service manual has pics of what the signal looks like but to replicate the signals it gives instuctions to press buttons on the navi unit and mine is FAULTY (i get some blue screen with JAP writing and cant make it turn off or anything) so i dont think I'll be able to work it out that way.
I was just hoping someone might know which wire is which to save me time trying to work it out myself.
Thanks.
https://www.sau.com.au/forums/topic/240888-r34-in-dash-lcd/#findComment-4218117
http://flatout.main.jp/driving/parts/bnr34mfd/
The above site is in Japanese so run it through a translater. its a guy in Japan with a gtt that has put in a mfd but as far as i can remember he did not have the sat nav to start with so i hope it helps. Failing that pm me with your email address as i have two PDF's with how to wire them as well as an operations manual.
Cheers
Ross
https://www.sau.com.au/forums/topic/240888-r34-in-dash-lcd/#findComment-4219966
Thanks.
ok so you want the GTR unit to be fully operational?
if so then there is a diagram for it on here. as for the rest depends on how you go about it. you can do comp video into it OR RGBs with fiddling. both of those require teh MFD to be modded.
don't worry about the GTT harness - disconnect it and leave it be.
https://www.sau.com.au/forums/topic/240888-r34-in-dash-lcd/#findComment-4221547
i got it from the for sale forum here, but if ure after one i would suggest importmonster.com.au or slidewizeimports.com.au
I paid $1100
If you but one you will most likely not get the piece of harness with it but you can get it from nissan for about $200, the part number for it is in one of my other posts in the Tutorials and DIY section
https://www.sau.com.au/forums/topic/240888-r34-in-dash-lcd/#findComment-4234229
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
