Hey all,
I have some spare cash and want to get one of these piggy back air/fuel computers.
I have read that the e-manage is supposed to be the best, but I have found it's generally twice, if not more, the price of the S-AFC II.
My car is a pretty much dead stock, I have a 3" cat back exhaust, performance clutch and a POD filter on the way.
Would the Apexi do the job no worries? or would the e-manage be a better buy even though it's more expensive?
Appreciate any help.
Cheers.
PS: I don't plan on upgrading the turbo or any other major bits and pieces, so I don't want to waste money on an e-manage if I would never need it.
https://www.sau.com.au/forums/topic/24090-s-afc-ii-vs-greddy-e-manage/
if u get a s-afc / e-manage and then get tune with ur current mods it wont make that much of a difference... plus u probably have to get retune once u get it boosted..
most skylines run rich once u start adding mods so u dont have to worry about ur car leaning out.... so im with hippy, get ur bolt on stuff ( dump pipe, ebc, fmic or wateva ) then the s-afc / e-manage..
I am confused why you say that the emanage was twice the price, I was interested because it was cheaper or the same for what offers more control (AFR AND ignition timing vs AFR only)
Hikariperformance: New Trust Emanage with ignition and injection harnless AUD$680.00
(Hikari) APEXI S-AFC AIR FLOW CONTROLLER AUD$600.00
(Belperformance) Super ITC Super Ignition Timing Converter AUD$500
Ned
extra 60rwkw...nice.
ned: according to www.greenline.jp the S-AFC II would cost me around $AU460 delivered, and the eManage and both the harness' and support tool would cost me $AU780 delivered.
Just to clear things up, I don't want to get the S-AFC II or eManage or extra power or anything like that, it's just to control the mixture and have peace of mind that it's not running too lean and pinging and etc. etc...
Well if ur a novice you probably wont need the support tool, just get a workshop to tune it for you. The money you save from not buying the support tool can go towards getting it tuned professionly.
I think eventually, once ive paid back the bank a bit more money, Ill go Emange and greddy boost controller. Seems that it would do everything important that a SAFC, AVCR and power fc does, for a bit cheaper, and ur able to tune it on a computer.
And looks cooler too. :P
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
    • Yep, agree with all of the above added on too. I just love the age old "what boost were you running?" Question without getting any other surrounding data. IE, may have ran 20psi, and lived for 12 years, but it was an 80 year old granma driving it to Bingo once a week and never took it over 2500rpm.
