  • 3 weeks later...
Still for sale.
Just curious.. I have been trying to follow this thread a bit. I have a R-34 GT-R Vspec on the boat heading out to me from Japan to USA... These are the rim's i want. Is this offset too much to use without Spacers?? I'd rather get a set of rims that does not need spacers.. if they do need them what offset would i need that wouldnt touch... a +15?
Mark
Mark
Hey Mark,
Yes, because they don't quite fit over my front calipers on an R33 GT-R, they won't clear yours either, unfortunately, without spacers. I have bought some slip-on spacers that I can give you if you bought these wheels, which allow the rim to still sit on the spigot (hub) and not on the bolts alone. Like you though, I preferred not to put spacers on the car.
I do know someone who has an R34 GT-R and, like me, he got a bit screwed by the person he bought the rims from, and was given the wrong disk type. He runs spacers on the car though and hasn't had a problem so far. He has 19" versions of the same Volk GT-Cs.
So check out the Rays Engineering website, which lists the three different disk types. +12 should actually be okay for an 18x10" rim on a GT-R, it's just the disk type which means the inside of the spokes interferes with the calipers. Otherwise they would be fine, so I'm told; they wouldn't require guard-rolling nor would they scrub on full lock.
Cheers,
Matt
nah they wont
They'll easily fit if you run stretched tyres, roll all guards and a slight flare on the rear, 2.5 deg neg camber on front.
These would look tough as f**k on a R33 GTS-t
would these fit onto a r33 gts-t they look like such a nice rim. shame they wont go on yours mate.
Thanks guys. Yeah AFAIK there are ways of making these fit on a GTS-t but as Hypnotik said it would take a bit of modification.
Cheers
Matt
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
    • Luckily for safety applications, with dedicated links not being used for any other traffic, you simply run ProfiSafe (or an equivalent safety comms protocol from other vendors) over the top of ProfiNet (if that's what you're using, or Ethernet IP if you're stuck in the world of American PLCs and not verking vis ze Chermans) and the redundancy is more about being able to know that you need to cause a system diagnostic lockout because you've lost one of your comms channels, rather than not knowing that you've lost your only comms channel. Granted, heartbeats and all that are possible and useable and all that, but some safety applications are are so time critical that you might not be able to afford a few milliseconds until the next check.
