Proudly Presents:
Micolour SAU-Vic DECA Motorkhana
When : Saturday 15th Nov 2008
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $75
Max Entries : 50 + Reserves
-= IMPORTANT ANNOUNCEMENT =-
The insurer of the event (AASA) has revised the supplimentary regulations to include helmets to be worn during all sessions. This includes the skidpan and all battles.
This also impacts passengers, as they must also now wear a helmet prior to entering a competition vehicle.
Please re-read the supplimentary regulations as they have changed.
Entry Form & Supp. Regs. : Click Here
Voting for Motorkhana's: Click Here
Event Schedule:
Results: http://sau.ferni.net/Scotsman/Results15thNov08.xls
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Micolour - Custom Refinishing, 7 Dissik St Cheltenham 3192, Ph: (03) 9555 8011.
https://www.sau.com.au/forums/topic/240918-micolour-sau-vic-deca-motorkhana/
  • Replies 166
Posted Images
Entry List:
1. Mick Eichorn R32 GTST
2. Tim Williamson R32GTST
3. Chris Thomson R33GTR
4. Martin Sullivan S14200SX
5. Mat Cross Toyota Corona
6. Alan Calleja R33GTST
7. Khoa (West) Toyota
8. Matthew Femino GTR
9. Greg Calmer Silvia
10. Simon Lesniak S15200SX
11. Mark Firman Datsun 180B
12. Alex Jovanovic Peugeot 306
13. Iain Thomson ForesterGT
14. David Sidebottom Datsun1200
15. Stephen Hugh-Smith SupraTT
16. Ryan's Bell Sileightly
17. Alexander Girsang R33GTR
18. Ben Winston R32GTR
19. Troy Galt Datsun1600
20. Antony Ivancic R33GTST
21. Jarrod Moore Sileightly
22. Dean Taylor EVO8MR
23. Jamie Lovett Porsche 911RS
24. Sam Zimbler RS Liberty
25. Nick Edlin GTST
26. Shane Janssen GTR
27. Tom Giordano R32GTST
28. Allan-Paul Ravell R32 4Door
29. Aaron Foo Evo9
30. Gary Mathews WRX
31. Alycia Mathews WRX
32. Nicholas O'dowd WRX
33. Jack Kuzior R33GTR
34. Chris Stacey R33GTR
35. Gareth Anderson R33GTR
36. Simon Baxter R32 4door
37. Matty Bray R32GTST
38. Steven Strekovski Mazda MX-5
39. Dinesh Rodrigo Mazda MX-5 Turbo
40. Andrew Richmond R34GTR
41. James Ward EVO X
42. Daniel Chin R34GTT
43. Che Boocock R33GTST
44. Dave Marinucci XR6T-axi
45. James Constable EVO9
46. Bart Kohler R32GTR
47. Jacob Radzikowski 180SX
48. Mark Homer Porsche 944S2
49. Ryan Verner WRX
50. Adrian Mueller WRX
Reserves:
1. Russell Gilder R32GTR
2.
3.
4.
will confirm 100% once i pick the car up saturday but do i need cams license?
also the date up top says Micolour Sau-vic Deca Motorkhana, Sat 3rd May 2008, DECA Shepparton
might wanna change that to november date :P
Yep I better - Done!
CAMS or AASA licence.
If you dont already have a CAMS or AASA license, dont stress - we can hook you up on the day, but it helps 10 fold if you bring the form already filled in and the correct money - we dont have change - so correct $$ is key :P
Also a note to everyone who already has a license - make sure you check your expiry dates - we cannot do renewals for CAMS or AASA licenses. This is something you need to sort out with them.
Cheers
B
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
