Hey guys,
What i had to do to post this was as soon as i go to make a new post it gives me about 2 seconds to write then the post box goes blue and can not write in it.
So i had to just push a few key get some text in the box before it closed then once i put the heading in posted it and used the edit button to write this.
Sounds like a browser issue, are you using Firefox by any chance with some plugins loaded? I'm thinking something like Adblock or NoScript that might remove or disable content. Have you tried a different browser and, if so, do you have the same problem? If not, disable all your addons then re-enable them one by one until you get the problem again. If/when you find it, you can either leave it disabled, or try to work out why it's doing what it's doing, you might have a bad filter in AdBlock for example.
Also if you have access to more than one computer (one at *cough* work for example) and don't have the issue there, it's likely to be a setting somewhere on your PC rather than an issue with your account :/
I tried fire fox google chrome and explorer same deal, I can still post on NS and other forums just SAU im having trouble with. I will try stuffing round with it and get back to you
internet security software might be disabling the field for some reason though............
do you have or have you checked it.
ps. holding the alt key down when doing a screen shot will only screen shot the window that is selected :P
Hmm could be im not sure what security we use here at work. Is it possible to stuff round with the internet security in the tools drop down??
Cheers for that will use that next time
Else where its fine just here at work and other work PC's, its just here that does it all other forums are ok.
How would i go about finding any info about the problem with the connection here??
Talk to the propeller heads where you work and give em curry about it.
Its either one of the following
1. PC level... ie I.E/PC Security setting/Anti-virus setting etc etc
2. Server/Proxy level... ie Mimesweeper or other blockers/filters and so on.
Its 110% not SAU if you can post from home fine.
Sorry we cant help anymore mate!
Cheers :D
Same thing happened to me, as a temp fix.. hit the stop button as soon as the page loads and you'll be able to post but it wont allow you to upload pics.
  • 4 weeks later...
  • 2 months later...
Hi Guys,
I still carnt get this problem fixed and now i carnt even get onto SAU from my work PC. I got incontact with our IT department and they sau its an issue with one of the host i have 2 pics that they think where the problem is.
this is the web path that it takes from my work PC
This is what it should look like he thinks
He thinks is a problem with the host “atlas.cogentco.com” taking to long.
Could someone please have a look at this to see if it can be fixed.
Cheers David
170ms is just because its in the US
Thats a fairly normal ping/hop to the US
Mine looks pretty similar to be honest and i dont have a problem.
Also - remove the first two entries dude, it gives out your direct IP, not very smart/safe :D
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
