Hey guys,
What i had to do to post this was as soon as i go to make a new post it gives me about 2 seconds to write then the post box goes blue and can not write in it.
So i had to just push a few key get some text in the box before it closed then once i put the heading in posted it and used the edit button to write this.
Sounds like a browser issue, are you using Firefox by any chance with some plugins loaded? I'm thinking something like Adblock or NoScript that might remove or disable content. Have you tried a different browser and, if so, do you have the same problem? If not, disable all your addons then re-enable them one by one until you get the problem again. If/when you find it, you can either leave it disabled, or try to work out why it's doing what it's doing, you might have a bad filter in AdBlock for example.
Also if you have access to more than one computer (one at *cough* work for example) and don't have the issue there, it's likely to be a setting somewhere on your PC rather than an issue with your account :/
I tried fire fox google chrome and explorer same deal, I can still post on NS and other forums just SAU im having trouble with. I will try stuffing round with it and get back to you
internet security software might be disabling the field for some reason though............
do you have or have you checked it.
ps. holding the alt key down when doing a screen shot will only screen shot the window that is selected :P
Hmm could be im not sure what security we use here at work. Is it possible to stuff round with the internet security in the tools drop down??
Cheers for that will use that next time
Else where its fine just here at work and other work PC's, its just here that does it all other forums are ok.
How would i go about finding any info about the problem with the connection here??
Talk to the propeller heads where you work and give em curry about it.
Its either one of the following
1. PC level... ie I.E/PC Security setting/Anti-virus setting etc etc
2. Server/Proxy level... ie Mimesweeper or other blockers/filters and so on.
Its 110% not SAU if you can post from home fine.
Sorry we cant help anymore mate!
Cheers :D
Same thing happened to me, as a temp fix.. hit the stop button as soon as the page loads and you'll be able to post but it wont allow you to upload pics.
  • 4 weeks later...
  • 2 months later...
Hi Guys,
I still carnt get this problem fixed and now i carnt even get onto SAU from my work PC. I got incontact with our IT department and they sau its an issue with one of the host i have 2 pics that they think where the problem is.
this is the web path that it takes from my work PC
This is what it should look like he thinks
He thinks is a problem with the host “atlas.cogentco.com” taking to long.
Could someone please have a look at this to see if it can be fixed.
Cheers David
170ms is just because its in the US
Thats a fairly normal ping/hop to the US
Mine looks pretty similar to be honest and i dont have a problem.
Also - remove the first two entries dude, it gives out your direct IP, not very smart/safe :D
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
