Ok, so I have a coolant leak from what appears to be the coolant lines to the turbo. I have taken the larger coolant hoses out from behind the engine to access the situation and from a distance appears to be a split hose (I hope.) The drama is trying to get to the other end of the hose (under the inlet) on the lines so i can get to the clamp so I can remove! I have got it up on ramps but cant see jack because of the gear box. Has anyone had the same problem and does the engine or at least inlet have to come off?
https://www.sau.com.au/forums/topic/240948-coolant-leak-hoses/
yeah had that prob, its either a heater hose from eng to flywheel, the water cooling copper line corroded and a pin prick hole or the 3/8" line from back of the head to the copper turbo water line, hahahhaaaa im a mechanic an let me tell u its f*ked to replace any of those hoses hahhaaaa :laugh: feel sorry for ya
I split one of those heater hoses that runs behind the engine (next to firewall) on the dyno and it nearly ended in tears. Had to go pick it up and limp it back to the workshop running rich as hell, was a prick to fix too :)
I should of stated its a 32 GTR. I knew it wasn't gonna be a pleasant job. So removing the hose means getting under the car to get the clamp off the hose near the head? Im dreading the process! Thanks for any advice.
its not a quick job let me tell u!
and ur arm looks raped by an oranatang by the end of it (grazes)
^ Haha... yeah it's been sitting for a couple of months now with this pissy little problem that's turned into a nightmare! Thought you might have to get ya arm up and around there then go in blinded. Might have to take ya up on that offer to BOOOSTN, give ya a buzz when I get time.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
