Hi, wondering if anyone could help with this please?
I have a set of OHLINS shocks (older type) for an R32 GTS-4 or GTR
The problem is with the rear shocks, they seem to be stuck on the stiffest compression/rebound setting and the adjusters don't seem to be working correctly.
The compression/rebound is supposed to be adjusted by inserting a hex key into the hole at the top of the damper rod and turning it. This works on the front shocks. When trying to adjust the rear shocks, turning the hex key clockwise, it turns smoothly with no resistance until it stops and goes tight, turning anticlockwise it just unscrews very smoothly with no resistance all the way until a grub screw comes out the top. Even with the grub screw almost right out they are still on the stiffest setting. The grub screw comes right out and just looks like a normal grub screw.
Would anyone have any idea what might have gone wrong or have a diagram of the parts in these shocks?
https://www.sau.com.au/forums/topic/24098-ohlins-shock-adjustment-problem/
Thanks for your reply.
Yeh checked the ohlins site and it doesn't seem to have these ones listed.
On these shocks above the lower mount there is a 12mm nut with a philips head screw in it. Think this is for filling them with gas but not sure. Also, I had to use a smaller hex key to turn the screws in the rear shocks.
What do the adjusters on your rear shocks look like?
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
