I'm thinkin' of blocking off my standard BOV in my 32 so I get the flutter but I've been told different stories my people.
Does anyone know FOR A FACT if it does any damage/excessive strain to the turbo? Or is it absolutely safe to do?
https://www.sau.com.au/forums/topic/240998-blocking-off-bov/
  • Replies 188
I have a piece of a compressor wheel from a rb20 turbo which blew out of my friends exhaust.
He blocked off his bov and was running 14psi..
Whether it was the blocked bov or the 14psi, i still have a cool looking piece of ceramic :/
ive had mine blocked off for a while now however i only blocked it off as my stock one was leaking under boost...ive recently bought a greddy type s bov..got it off a mate cheap and only bought that one coz couldnt get my hands on a gtr bov..
but the fluttering is fine...i still remember driving past some yr 8 skool kids and letting the flutters go off lol all i could here from the kiddies was ohhh woooww hehe i a had abig grin then lol
i don't think it'll effect it much if you're running standard boost! but if you start uping the boost it'll be safer to leave the bov the way it is!
and if you want a flutter you can get an aftermarket one and tighten it
That's exactly what I think! That's why I'm unsure.
lots of cars dont have them and run fine. mine never had one from factory. u know why manufactures use bov's now..? noise polution. they dont want weird tu tu noises coming form their engines. the average person buying a car would be like wtf that aint right. thats why some cars come with 4 cats in their exhaust systems when only one is required. to keep cars running smooth and quiet.
Edited by steveP
The reverse flow back across the turbo acts on the compressor wheel and causes the turbine shaft to reduce in speed quicker than it would naturally. When the throttle is opened again, the turbo will have to make up for lost momentum and will take longer to achieve the required speed, as turbo speed is proportional to boost/volume flow. (This is known as Turbo Lag) In order to prevent this from happening, a valve is fitted between the turbo and inlet which vents off the excess air pressure. These are known as an anti-surge, bypass, blow-off (BOV) or dump valve. They are normally operated by engine vacuum.
but a bov releases all the air. with no bov, the air between the turbo and throttle body gradually escapes back out the intake system. during gear change or whatever, theres still boost in the intake pipes/cooler, so it wont need to spool up all over again.
and before someone goes emo and cuts themselves saying it damages ur turbo. turbos are very robust. they handle high boost pressure and extreme heat for 100,000+kms (average life of a turbo). so releasing the air back out the intake system 'a little slower' is going to do f**k all to a turbo.
Edited by steveP
That is from the 14psi through a stock turbo, Blow off valve will not effect the rear wheel nor will it effect the front wheel as much as you think. The main concern when not using a BOV is because the sudden surge of back pressure puts strain on the bearing and seals inside the turbo from the back and forth movement it will get during this time. A blocked Air filter can also cause alot of wear.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
